rwilliams
- Sep 5, 2004
- Bryant, Arkansas
Hello
I need help. I am looking for some experience/expertise with a K O Lee Tool and Cutter Grinders. I recently acquired a B300 grinder in good condition. It probably needs new bearings in the B923 motor, in this model the wheels mount directly on the motor shaft. It makes a bit of noise as it comes up to speed and then gets gets quiet and smooth.
However, I cannot open up the motor case to get to the bearings until I remove the inner wheel flanges which are pressed or possibly screwed on to the shaft as each has a pair of holes for a pin spanner.
If anyone has done this and can provide advise or has insight information on removing the wheel flanges it is most welcome.
Pictures will follow.
Keep your powder dry and bubbles level.
Bob
Bob
