I've ended up with a 2001 Kaeser SK19 screw compressor that was one of a pair from a small manufacturing facility, unknown history, sitting for about the last 6 years. They robbed a sensor off of this one and drained the oil off to remove it before I ended up with it, now I need to replace the oil. It holds 3.25 gallons of Kaeser sigma m-460 oil according to the sticker. Presumably that is what is in there. I'm told the unit holds a good bit of oil internally that remains inside even after draining so compatibility with existing oil is important even if I drain what may remain. I don't even know if this thing works, so I'm not too anxious to buy a $250 5 gallon bucket of oil just to test it, so I decided to do a bit of research on screw compressor oils. From a bit of googling I think the Kaeser m460 is iso 46, I was told alternate compatible oils are Chevron gst46 (gas turbine mineral) , Castrol Hyspin aws46(mineral oil), Mobil dte medium, Exxon Nuto h 46 (looks like mineral), and Shell Rotella 10w/Shell comptella oil 46/ Shell oil S.9159. I'm told kaeser oil is not compatible with food grade or sullair oils. Looks like a bunch of compressor dealers have found whatever the secret stuff is and repackage some generic oil and mark it up to sell as compatible by brand. Is this stuff just iso 46 hydraulic oil? Additional googling indicates ATF is among the best quality of hydraulic fluids, but never seems to list a viscosity in specifications. So whats the difference between Kaeser m460, iso 46 hydraulic oil, and ATF? They all are around the same price...I suspect the rotella 10w may not be the common rotella straight grade 10w engine oil or am I wrong? that stuff or regular iso 46 hydraulic oil would be ideal to test this unit with as I can probably pick it up locally cheap, and if the machine works I can drain, do a filter change, and refill with the OEM kaeser stuff. Opinions?
