MG88
- Nov 2, 2009
- Western New York USA
Is it possible to use wax or some other lubricant to prevent the slots where the ruler interfaces the head of a cast iron combination square from wearing down over time?
Keep the slot for the blade clean, free of crud, and lube with Starrett M-1. You should get a life time of use out of a combination square set. I have one of my dad's I've had since I was about 12 years old, still good as new. Of course, I have several sets that I float around in the shop, and my use is not that much, just a occasional use, meantime, they are stored in my machinist chest until needed. Your mileage my vary. Ken
Don't loan it to anyone no matter what. If you have issues with humidity put your tools in the tool chest when tot in use. Wax might help but it will wear off.
I like rem oil (a brand of gun oil) for tool lubrication it doesn't get sticky.
Thanks! Someone told me to expect only 1-2 years of regular use before it looses accuracy. Didn't sound right to me, but maybe they were referring to an aluminum square. Does the lubricant actually stop wear?
I'm curious where that 1-2 year claim came from.
A carpenter friend who is always buying new tools. It seemed odd to me, too, but I'm still learning. I didn't want to do anything to damage this tool I just purchased.
"Does the lubricant actually stop wear?" Well, no. Nothing will ever stop wear if the square is being actually used. Motor oil in an engine keeps the wear down to a bare minimum, but engines still wear out. So will squares. It is just a matter of how long that takes.
What type of lube or preventative and how well it works is a matter that depends on many factors. For instance, in a dusty environment, use of an oil could actually trap that abrasive dust between the surfaces and cause them to wear faster. Under more normal circumstances, that same lubrication or preventative could greatly decrease the wear. It just depends.
I have about a half dozen adjustable squares, some many decades old and have not seen any great problems with only occasional application of a very light coating with oil. I apply it with an oily rag and wipe it down after that so very little is left on the rule. And in most cases, these applications with oil are months apart.
However, I will suggest something that will probably result in a lot less wear than even keeping them immersed in a bath of oil could. Get a pair of Flat, Ground Stones and clean up the edges of the blades on an occasional basis with them. Flat, Ground Stones are abrasive stones that have been ground flat with a diamond wheel on a surface grinder. They are very flat. They are purchased in pairs so that they can be carefully rubbed together before each use. This rubbing is to eliminate any projection above their flat surface that could scratch the object being treated with them. When you rub them together on the first few strokes you will feel some resistance but then they quickly just glide over each other. That is when they are ready for use.
These Flat, Ground Stones are what is being talked about when a machinist says to stone a milling table. And they can be used on any flat surface, like the edge of the blade of a combination square. Lightly stoning those edges will eliminate anything that rises above a flat surface and greatly improve the edges of all but the most premium square blades. When used with normal pressure and for only a few strokes, they will not remove any metal from the flat edge of the metal blade, only raised areas that you do not want. Be sure to hold the blade square to the stone while doing this. You want to stone the full width of the edge and not just one corner.
I would suggest that before stoning a square's blade for the first time, that you lap it on a sheet of extra fine sandpaper (400 grit or higher) that is held down on a sheet of float glass. You should only need a few strokes on this sandpaper as you do not want to remove much, only any larger burrs that may scratch the Flat, Ground Stone. Do this lapping ONLY ONCE. Never on a repetitive or regular basis. That's what the Flat, Ground Stones are for.
This is a good treatment for other precision surfaces in your shop like 1-2-3 blocks, machinist's levels, etc.
The takeaway seems to be, don't abuse it and it won't change to a noticeable degree. Other than that, it can be filed. I wonder if a very thin shim could be inserted to correct as well?
What kind of work are you going to use these for?
Cabinetmaking, primarily.
Notice
