Keeping swarf out of quick change tool holders set screws
Page 1 of 3 123 LastLast
Results 1 to 20 of 49
    Aug 2004
    Virginia
    2,454
    179
    971
    Default Keeping swarf out of quick change tool holders set screws
    For some reason it seems like I am spending more and more time digging swarf out of quick change tool holder set screws. I keep one of those magnets on a stick near the lathe and that works pretty well on ferrous swarf only. I know this is a small matter, but it is annoying when you are in a hurry. Does anyone out there have a slick way to keep the set screws clean? Removing the holder and whacking it on the bench upside down does not always work. I actually did a search but all I could think of to search on was "cap screw plugs" and that was not helpful. Thanks.
    Jun 2012
    Michigan
    5,082
    4634
    3064
    Just air blast them whenever you can.
    Maybe get a set of those nozzles that have small tips, they work really well for stuff like that.
  3. Likes Gordon Heaton liked this post
    Oct 2005
    17,272
    an air hose works wonders, if your concerned of extraneous flying objects, put a shop towel over top.
  5. Likes Mtndew liked this post
  6. #4
    Dec 2016
    Kentucky
    232
    35
    73
    Maybe switch to short bolts??? I like the low profile of setscrew too but if its that annoying would be a solution
  7. #5
    Jul 2006
    Hillsboro, New Hampshire
    8,909
    2139
    6158
    Quote Originally Posted by mmarquette View Post
    If someone's looking for some quick income, running a bunch of replacement square-head bolts for tool holders might be a niche. Just like the olden days...
  8. #6
    Aug 2004
    Virginia
    2,454
    179
    971
    I actually do use the air hose sometimes but I hate to send chips flying into weird places. Yes Digger a shop towel would stop the chips but then I've got a shop towel with chips stuck in it. I know this sounds kind of trivial but I thought someone might have an elegant simple fix that I just haven't thought of. I do like the square headed bolt idea. Back in the dark ages, when all I had was an SB9, I could use the one wrench for the Armstrong tool post, the compound swivel and the carriage lock.
  9. #7
    Oct 2005
    17,272
    Quote Originally Posted by crossthread View Post
    I forgot....I have seen custom made blow guns for radial drill operators (fully OSHA compliant)
    They take a normal blow gun with the "max 30 psi vent hole" add a longer tube (1/4" steel tube usually)
    Add a 90 degree bend, and fasten a inverted funnel near the outlet end.
    Drop the pipe end in the hole, and the funnel stops most all the chips.
  10. Likes mountie liked this post
  11. #8
    Feb 2014
    Sunny South West Florida, USA
    3,315
    11430
    3712
    Why not just go to an off the shelf hex bolt and matching socket then?
  12. #9
    Jul 2006
    8,909
    2139
    6158
    Quote Originally Posted by TeachMePlease View Post
    Have you no shame, sir! What about tradition, of hearkening back to Ye Olden Days, when Square was Cool?
    Hex is for newbs.
    [Real answer: regular hex bolts have a short head height, which means the wrench is less stable if left in place. Typical square head screws of this type have a head height great enough that the wrench stays stably in place. Custom screws with tall hex heads would work fine]
  13. Likes TeachMePlease liked this post
  14. #10
    Apr 2016
    105
    59
    53
    put a piece of electricians tape over the set screw holes, replace as needed?
  15. Likes Hopefuldave liked this post
  16. #11
    Aug 2004
    Virginia
    2,454
    179
    971
    I was looking for something a bit more elegant then tape Matthew. Plus everything is covered in cutting fluid or oil. I think tape would be a PITA. I was thinking some kind of little plastic doohickey like the vent on a gas can. Captured so you don't lose it and cheap.
  17. #12
    Sep 2006
    SW Wisconsin
    554
    37
    144
    How about a piece of line from a string trimmer? Fast, easy, disposable.
    Ed.
  18. #13
    Jan 2007
    Norfolk, UK
    19,642
    15080
    15249
    I suggest you find a machine shop to make some tall hex or square headed bolts.
  19. #14
    Jul 2006
    8,909
    2139
    6158
    Quote Originally Posted by Limy Sami View Post
    Can you get to a lathe while you're quarantined? Win-win!!
  20. #15
    Mar 2006
    Wisconsin
    1,162
    14
    412
    McMaster sells plastic dust covers for grease fittings. They come in 2 sizes 15/64" ID and 25/64" ID. maybe something like this will solve your problem.
    McMaster-Carr
  21. #16
    Nov 2018
    Michigan
    384
    180
    214
    What size? I can experiment a little with sizing some caps that have little stems and just pop an o-ring around the stem so it holds itself in place until you want to grab it. we could even go extra fancy and cut a hex into the bottom half of the cap so it seats real nicely.
    Or, if you want to do the experimenting go for it.
  22. #17
    Jan 2005
    Houston
    6,123
    707
    2854
    Compressed air, a spray of carb cleaner, more compressed air.
  23. #18
    Dec 2008
    IL/WI border
    3,420
    1215
    1063
    Longer [set]screws?
  24. #19
    Jan 2007
    Norfolk, UK
    19,642
    15080
    15249
    Dunno, but I've already got one
  25. #20
    Jan 2005
    Victoria, Texas, USA
    4,221
    2497
    1091
    McMaster-Carr has square head set screws, only problem they are cup point. Probably wouldn't matter to most, if so, face them off.
    McMaster-Carr
    Ken
