For years I have used short steel set screws with the top thread either staked over or a tiny TIG tack to stop the set screw at the chamfer in my parts. This keeps any small pieces of media out of the holes.
If I don't plug them it's a PITA ordeal to fish out and break up anything that gets in there and clean it out.
The problem is sometimes the parts get forgotten about overnight and we get rust stains in the holes.
Most all the blind holes I have are M6, M8 and M10. The M6 seems fine. We get any media that small out of the tumbler so primarily it's the M8's and M10's I need a better solution for.
I was looking to buy plastic set screws, but I can't find M10's online anywhere. I figured before I called around tomorrow I'd ask here if anybody uses something else to plug the holes or if you know where to get M10 plastic set screws by the hundreds.
Whatever I plug the holes with needs to be about flush so the finish is even right up to the chamfer. If I just shove a bolt in the hole there is a ring around each hole. That doesn't work.
I know I can make my own, but I don't want to. I have enough shit to do and these are kind of a consumable as they get lost and eaten away over time. Staking/tacking steel set screws is tedious enough.
