Hi,
I have three DMG machines: DMU100, DMC835V and DMU60E
I work in everything from aluminium to hardened marterials, I have a big variety of my tasks.
We have been very satisfired with KennaMetal in the past in connection with solid carbide end mills and drills. We use their F4AS Harvi end mills for everything from mild steel to hardened materials - they work like a charm. They are the only end mills we order as they suit every task (for aluminium we use another line of end mills from a local brand).
The GoDrill B04x and B05x drills are our favourite solid carbide drills. They can be used in everything from aluminium to hardened materials - a really good drill both in life time and perfomance.
Since we have been so satisfired with the products from KennaMetal so far, I find it hard to choose between Hitachi and KennaMetal. I have always been told that Hitachi was among the best you could get. I have tried the ASRFB Mini Turbo4 from Hitachi and found it quite good. Then I tried the AHUM15 also from Hitachi, and it was a mixed experience. Lifetime has not been as expected, performance such as Ap and Ae seems reasonable and also the rate for removal of material seems to be good.
So what do you guys think I should go for: Hitachi or KennaMetal ?
Furthermore, the salesman from KennaMetal advised me to buy high feed mills from Stellram, as he found the high feed line from Stellram better than the line from KennaMetal.
So what to choose ? - Hitachi, Stellram or KennaMetal ?
I need input, thought, feedback and would like to hear others experiences.
Best Regards
Vifa
