Hi keithmech:
The traditional way of course is to grind them on a mag chuck using a tool and cutter grinder with the head tilted over or the wheel dressed for the front clearance and a finger from a convenient spot to index the teeth.
So now the job becomes a simple plunge grind one tooth at a time, and there are lots of examples of keyway broach grinding setups in all sorts of old machine brochures.
This works so long as the teeth do not have any back relief (narrower as you go down the tooth toward the cutter body) but as soon as they do, any grind at all will put them out of spec because they get narrower and narrower as the teeth get shortened more and more.
Face grinding the front rake so each tooth gets skinnier and skinnier will always make each tooth narrower and narrower if there's side relief, so I've never seen them done that way.
I don't know that much about the machines, I was exposed briefly to them many moons ago, but so far as I remember, Davis keyseat cutters did have side relief to keep them from rubbing in the slot, so unless my memory is playing tricks on me, the principle applies.
I also do not know if an out of spec narrow broach can be simply run in several offset passes to bring the slot to width or whether the broach has to be tossed out when it gets too skinny.
Logically you'd think they could, but I don't know enough about them to be sure.
Cheers
Marcus
