Keyway broach 5" - 6" long help - Page 2
Results 21 to 40 of 42
  1. #21
    Jul 2007
    Missoula Mt
    1,449
    62
    733
    Wrong machine tool, use a slotter...Phil
  2. #22
    Mar 2005
    Kansas
    8,787
    630
    4515
    Quote Originally Posted by Phil in Montana View Post
    What he said.
    Chip load is ground into the broach. The only way to change is to angle grind the back of the broach.
  3. #23
    Apr 2004
    Modesto, CA USA
    8,941
    1773
    How about broach it say 1/2 way deep then remove the tool and bush out the gullets. Similar to peck drilling.
    Bill D
  4. #24
    May 2012
    Pittsford, NY
    1,206
    842
    854
    If the material is too ductile, you get a little roll of chip in each gullet. Trying to back out requires breaking off every chip. The chips try to wedge between the cut and the back relief on every tooth.
  5. #25
    Mar 2003
    Vermont
    533
    131
    149
    Quote Originally Posted by wheels17 View Post
    I agree, never reverse push a broach out of the cut. Just remove the bushing and lift the broach out of mesh.
    As mentioned, all of this is clearly detailed on Dumont's site. Cringe reading bad advise.
  6. #26
    Dec 2008
    minnesota
    222
    59
    217
    Here is a random thought:
    Perhaps you could make a broach bushing with the back of its slot
    angled about half as much as the broach is tapered.
    Then use shims half the thickness of standard and take more and lighter cuts?
    (passes) ?????
  7. Likes Overland liked this post
  8. #27
    Jun 2019
    South Dakota
    153
    47
    52
    Dumont D series is designed for up to 6" cuts. I've used them for such with no issues in both steels and irons. May not be feasible for short run jobs, cost wise, but if you'll be using them again later anyway they make life easier.
  9. #28
    Nov 2017
    South Carolina
    203
    45
    56
    Refer to the experts - Dumont.
    The issue is going to be chips loading the gullets, and the force to push so many teeth in contact at the same time.
    The depth of cut is designed into the broach, with the progressive height difference of each tooth.
    Three ways to reduce this that I can think of:
    - grind a taper on the back of the broach to reduce the height difference of each tooth,
    - grind down each tooth a little progressively from the thickest end.
    - make one shim a tapered shim to have the same effect, then you add or remove tapered shim on each pass so you're effectively almost halving the depth or length of cut. Easy to make the shim on a surface grinder.
    It all depends on what Dumont says.
    Bob
  10. #29
    Nov 2017
    382
    251
    250
    I've broken a tooth out of a broach trying to broach too much length. If permissible, drill a hole slightly larger than keyway width at the middle of the part, broach inline with the hole. This will allow the chips to escape. If necessary, plug the hole afterwards.
  11. #30
    Jul 2006
    Hillsboro, New Hampshire
    14,330
    3135
    9528
    I don't know if this will help, or if you want to risk it, but I've made fixturing to turn a CNC machine (VMC, but could be done on a lathe too) into a broaching machine.
    Ideally mounted in a way that puts no load into the spindle bearings, but with sufficiently light cuts even that can work. Stable, stiff cutter holding is key (sorry), as is patience with just taking lots of light passes.
    No need to have a full-width cutter either, for wider keys use a narrow cutter, cut the two outer (to final width) sections), then chase out the middle. It's stable in that order, I wouldn't do the middle and then the two sides.
    [This also can work for profiling gears and similar non-rotary cutting]
  12. Likes 52 Ford liked this post
  13. #31
    May 2021
    Virginia
    346
    374
    89
    Stefen Gotteswinter on YouTube has at least one video doing something that with a manual mill. I wanna say he cut internal splines in a socket for some odd fasteners on an aircraft engine - something like that. Must work well, he sold his shaper. Given, space is at a premium, but still.
    Sent by telegraph using - .- .--. .- - .- .-.. -.-
  14. #32
    May 2021
    Virginia
    346
    374
    89
    Here ya go. Cutting an internal keyway on a manual mill.
    https://youtu.be/s7MBl_cWXrc
  15. #33
    Jul 2006
    14,330
    3135
    9528
    Quote Originally Posted by 52 Ford View Post
    I'm lazy, I prefer my machines do the work...
    Oh, and:
  16. #34
    Apr 2018
    9,782
    4699
    Oh, and:
    Why go halfway ? More parts, more better
    https://youtu.be/GCfqCiRvZA4
  17. #35
    Jul 2006
    14,330
    3135
    9528
    Quote Originally Posted by EmanuelGoldstein View Post
    My second-favorite organ...
  18. #36
    Apr 2018
    9,782
    4699
    Try this then, it's a little different
    https://youtu.be/UMwctRJcHcc
    If you like cnc and Ingersoll planer mills, you have to appreciate pipe organs
  19. #37
    Jul 2006
    14,330
    3135
    9528
    Wrong-O, you commie rat-bastard organ-dealer. Are you stealing those organs? What churches have woken up in a bathtub filled with ice, with sloppy stitches covering over the wound where their organ used to be?
    Hummm??
    Besides, I'm more of a Jacquard loom kinda guy. Now THERE'S your connection to our beloved CNC machines.
    [True story: when I was a young Milland and going to summer camp, I actually made a shuttle loom in the crafts barn, and used that loom to weave a very nice belt. I also made an investment cast sterling silver ring while I was there.
    I should have gone to art school and become wealthy, instead I became a machinist. From young artisan to grizzled shop ghoul - there's a narrative arc with a bad ending...]
  20. #38
    Apr 2018
    9,782
    4699
    Punch cards, pffft. Player pianos and organs use paper tape. Modern
  21. #39
    Jun 2009
    Michigan, USA
    5,670
    3566
    2603
    Quote Originally Posted by Bill D View Post
    Bill D
    Have you ever tried to back out a broach that is halfway through the cut. I have a tip for you. Make sure that you have a spare broach handy first.
  22. #40
    Jun 2009
    Michigan, USA
    5,670
    3566
    2603
    I've cut keyways this way but good luck cutting one that is 6" deep and over 1/4" wide.
