Knurl Cutting Tool
Results 1 to 11 of 11
    Nov 2019
    UNITED KINGDOM
    Default Knurl Cutting Tool
    Hi, new here!
    I'm looking at making a knurl cutting tool for some oil caps I'm making in aluminium. I've based the design off of another diy tool I found on google
    Here's my design, I've incorporated a 25mmx25mm bar on the back so it can be mounted on the turret on our cnc lathe.
    Now my main question is, what wheels do I need to produce a diamond knurl? I've been looking at some 15 degree 1mm pitch wheels from cutwel (I'm from the UK) Does it matter what wheel is mounted on top or bottom and what way they face as long as theyre opposite? As I've seen there's left hand and right hand wheels.
    As far as setting the wheels up, again I'm gong to use the same method from the other diy one I found, where you make effectively a protractor gauge that goes between the 2 wheels, and put a bit of small rod in the side of the round bar and line it up with whatever degree is needed, and then do the same but opposite for the other wheel.
    I think I've covered all the topics I can think of so hopefully someone can shed some light if I'm on the right tracks or not!
    Sean
    Oct 2010
    Dewees Texas
    2,403
    27
    657
    This may not be much help, But I have taken a commercial Zeus cut knurl and made a ne shank for it to use on a gang tool lathe. The knurls I use are straight(no angle). The Zeus head may have different geometry than your set up and that may make the difference. One thing on mine is the spacing between the knurls is changed for different OD work.
    Checked again the spacing between the shafts stays the same but the shafts are geared so they rotate at the same angle and that angle is what changes for different diameter of work.
    Jan 2014
    Montana
    124
    47
    32
    I prefer scissor style knurls. There is no problems with deflection as one roller is on one side of the bar and the other roller is on the opposite side of the bar.Not so much of a problem in Aluminum, but harder materials they are the best. IMO
    Aug 2005
    Toronto
    4,827
    3272
    3689
    to get a diamond knurl you use straight wheels (at least I did). Here's one I made, did it as a build series in home shop machinist. I makes great knurls, single pass at speed. What makes this tool really nice to use the height adjustment and geared rotation of the arms....they can otherwise be a real pita get an even pattern with. Probably more than you were asking for, but that imo is what you want out of a cut knurling tool.
    Sep 2006
    Stillwater, Oklahoma
    1,312
    92
    708
    I built Michael's (McgGyver) design and can vouch for it. Only a slight mod for a QCTP so it added a dovetail and used the height adjust standard for tool posts. A good design and as usual, beautiful work.
  6. Likes Mcgyver, gerritv liked this post
    Sep 2006
    Nevada
    345
    22
    91
    Mcgyver
    Do you know what issue the knurler appeared in?
    Ken
    Mar 2009
    5,174
    97
    955
    Quote Originally Posted by MiniMadSean View Post
    Looks similar to what I use. Once the tool is on center to the work I find it easy to adjust the angle of the wheels. Set one then tweak in the other one.
    HARDINGE C30A KNURLING Tool H-388 - $149.99 | PicClick
    Sometimes I insert a piece of tin between the tool shank and the allen screws to protect my pretty little tool.
  9. #8
    Mar 2016
    CANADA
    Ontario
    133
    128
    73
    5 Issues starting Mar/Apr 2010.
  10. #9
    Mar 2019
    Massachusetts
    108
    42
    59
    HARDINGE T8 5/8" Knurling Tool w/ 5/8" Shank H-396 - $149.99 | PicClick
    This Is what I use on Screw Machines. Just have to change the angle of the rolls to get whatever knurl you want.
    I even put a drill in it to drill and knurl in the same pass when needed.
  11. #10
    Feb 2007
    St. George, Utah
    914
    459
    605
    Quote Originally Posted by rbregn View Post
    I prefer scissor style knurls . . .
    Have you ever used a cut-knurl? Whole different concept, better result:
    Quote Originally Posted by Mcgyver View Post
    . . .it makes great knurls, single pass at speed. . .
    Check out the pictures in post #4.
  12. Likes gerritv liked this post
  13. #11
    Mar 2016
    CANADA
    Ontario
    133
    128
    73
    This style will get you a straight knurl, which I prefer for better grip (old fingers). This is from a Guy Lautard design.
    This is how I sharpened the cutting edge, I used whatever angled knurl I happened to have. Not sure this would stand up to CNC pushing out work but likely good enough for testing the concept.
  14. Likes JHOLLAND1, Mcgyver liked this post
