Knurling flat surface
Results 1 to 7 of 7
    Mar 2020
    Default Knurling flat surface
    I have a 1" square steel bar with a 1/2" deep, 2" wide notch machined into the bar. I need to knurl the bottom of the notch. Can it be done?
    Oct 2005
    dexter mich
    296
    12
    72
    that is a job for a shaper and you will have to make a one sided knurl tool and flip it to get to each side
    Feb 2006
    Indiana
    13,135
    722
    4072
    I have some knurling wheels with both male and female diamond knurling on the OD. They are made in many sizes. Here are some that are 1 1/4" diameter by 1/2" wide x 1/2" bore.
    PH Series - 1-1/4 x 1/2 x 1/2
    You will have to build a machine to roll the wheel along your slot under pressure from a top plate because the wheel will only go into a less than 3/8" deep slot if using a 1/2" pin to apply the force. Or AccuTrak will make larger diameter custom wheels. Or redesign your project to line the bottom of the slot with a thin knurled plate.
    Larry
    Apr 2011
    Nebraska
    1,288
    1902
    397
    Why not just mill it with a 60 (or 90, etc) degree point end mill? 60 Degree Point Drill Mills
    -Ron
  5. Likes kustomizer liked this post
    Aug 2015
    Illinois
    1,489
    1091
    635
    Quote Originally Posted by MetalCarnage View Post
    -Ron
    Trying to cut with the end of the tool results in zero peripheral speed at the point. It would not cot at the extreme end, just drag through the metal until the tip broke off.
    Aug 2005
    Toronto
    5,085
    3428
    3961
    Quote Originally Posted by Illinoyance View Post
    how do single point engraving cutters work?
    instead of an angled cutter, tilt the head and use an endmill.
    Jun 2008
    Bellingham, WA
    4,118
    989
    2257
    One-off or many?
    Does it matter if/when the bar is warped due to knurling?
    Does the knurling have actually start and end at the very ends of the notch?
    I guess we are to assume the “steel” is soft and not prone to work hardening.
    Denis
