You have to size your blank diameter to the pitch of the knurled or you will likely have trouble getting them to track properly
. I tried all the mathy stuff—-useless. apply lube oil (not cutting) turn fairly slowly and advance fairly fast. Don’t over roll the knurl and make it turn to powder. Tighten the scissor a bit more and repeat about 2 times. Voila! Done.
Just get out some scrap 12L14, 4140 PH, 6061 AL and spend an hour practicing. It works, is not rocket science, and allows for some handy grips—-both coin and diamond knurls. Then there’s decorative knurling, cut knurls etc. But just stick with diamond and coin knurls—-that will serve 99% of most folks needs most of the time.
Denis
I disagree with you on that. The theory about making the pitch of the knurling tool relate to the diameter of the work is similar to cutting gear teeth. Nobody likes for the last tooth to be thin.
JH
While you don't aleays have to drive yourself mad with calculations with short runs and one off's It pays to do it for production runs . You will have better results and a more consistant knurl part to part
The maths does work,how else would you get a good knurl on a required diameter?
Do not use cutting oil and run fairly slowly??? Have you ever watched a screw machine forming a knurl? They definitely use cutting oil and run at a surface speed that the main operation requires.
Notice
