Mud
- May 20, 2002
- South Central PA
I saw this on Ebay. Is the taper on the faceplate end the same as an L style mount?
View attachment 228394View attachment 228395View attachment 228396View attachment 228397
I want to make one of those, but in D1-6!
I have a couple I MUST make for D1-3 and D1-4. Different lathe for-sure, mill only "maybe".
With D1, it is "more better" to pull-in with short cap screws from the back into the threaded anchor holes where the now-removed camlock studs were meant to go.
Providing enough depth in an adaptor to utilise standard camlock studs wants about three times as much net stick-out/bearing overhang.
And then.. one has to make or buy the locking cams and their springs, and machine their mounting holes. Any given item of D1 nose-art becomes "almost" dedicated when back-bolted instead, but acquiring an extra one or two "goodies" for other "conventional" D1 use should beat the avoidable PITA and expense of "full" D1 compatibility in an adaptor.
Or so at least one lazy old sod is betting. Haven't had the "round tuit" chit show up in the postbox just yet.
Safe bet. For-sure others have done this back-bolting 'stead of studs arredy. I just don't recall seeing fotos on PM.
2CW
Try looking at early model Emco Maximat 11 lathes. The chucks mount via threaded studs onto the spindle nose. I forget the designation - A1? B1? There's definitely a DIN standard for it.
My Maximat 11 has the same spindle nose taper, diameter etc as D1-3 but no cams. Frankly it's a PITA and I'd rather a D1 spindle nose. So must have a lot of other people because the following variant went to D1-4.
Thanks, Pete,
Already familiar with it "A" and variants. The face bolt / ELSE conical pinch never BOTH Cazeneuve dual-use proprietary nose is another of similar persuasion.
Primary disadvantage comes with goods such as chucks with large-diameter scroll plates in the midriff. Direct in -line face bolting is challenging, most of the realistic size matchups, need an intermediate adaptor to at least get a bolt-circle out beyond the space the scroll plate blocks.
My need actually IS Cazeneuve-driven easily as much as mills. Rather puny 40-taper here, dare not get greedy. A 50-taper is waaaay heavier and stronger. OP is in tall clover good fortune there.
I'd like to be able to "port" a seriously extensive and already paid-for arsenal of D1-3 goods to the HBX-360-BC. Fabbing a Cazeneuve mounting plate is challenging, and the factory warned against DIY vs their specialized equipment.
The challange lies in the shallowness of the ID taper. Less than 2 degrees. It takes VERY little error for the drawn-tight into interference zone position to no longer come into near-as-dammit simultaneous bearing on the flat ring.
Far pickier than the steeper taper of A or D1.
Hard work, small gain. On which score, I rather suspect we both own exactly the same "side step the issue" opportunity.Yeah well, exotica has its quirks.....
I'd like to be able to swap chucks et al between the Chipmaster (D1-3) and the Emco. In theory this shouldn't be all that hard. In practice one needs to make studs with 2 diameters, big end screws into the D1-3 backplate, small end through Emco spindle.
Too much like hard work, defeats the purpose of quick-change.
Notice
