Technical Ted
Cast Iron
- Dec 31, 2017
I was given the subject machine. I would say probably made in the 60's. Weighs 800-900 lbs. Had to re-build the gearbox with new bearing and seals, but everything else seems to be in good order.
My question is about the motor mount. It looks like part of mine might be missing or has been changed. The motor is mounted on a hinged plate and the belt tension is only supplied by the weight of the motor swinging down on this hinge. There is no tensioning screw or other device to adjust tension. Is this correct? If not, can someone please post a picture of theirs please?
Ted
Ted
