DennisGa1
- Aug 3, 2021
- Milford New Hampshire
We've got a 15 X 54 Lablond Regal lathe and it won't go into gear past 494 RPM. All gears from 494 down work. When you try to go higher than 494, the spindle stops oscillating. I've checked the microswitch behind the gear shift knob and that's ok but not sure where to look next. I don't have a repair manual but I'm thinking there must be a switch in the valve body because the only thing that is moved when trying to shift gears is the shift knob. If anyone has any advice on where to look to remedy this problem, it would be greatly appreciated. Thank you in advance!
Dennis
Dennis
