Hey,
I remember as a teenager taking a tour of a plant where they built fuel controls and they built them by making very thin sections, stacking those sections and then brazing them together in a furnace.
So I'd like to do something similar, stack a sheet of stainless, a sheet of copper and then another sheet of stainless, sort of laminate them together. The shape would be rectangular if it matters. But the joint can't just be around the edges because I'm then going to take that "stock" and cut something out of it so I want the "stick" to be throughout the joint so the pieces I cut out will stay together.
Any ideas on this, how I could go about it? I think it could be done in a vacuum furnace, but those are pricey for a side project and I'm not sure if even that would work joining flat plates together. Would a regular heat treat furnace do it with some extra prep and flux? What about a torch? Could I use copper itself to join the two stainless plates?
Any thoughts on this would be appreciated.
