Lancer 2000 nitrogen re-fill problems
Results 1 to 10 of 10
    Jul 2008
    Philadelphia
    2,150
    596
    493
    Default Lancer 2000 nitrogen re-fill problems
    The Cincinnati Laner has a N2 counter balance for the Z axis. My charge and tank are low enough to where moving Z is causing too much current draw and faulting.
    problem is the fill port is a 1/4 BSP schrader valve. I have no problem recharging, however finding a female fitting to mate with the aforementioned BSP fitting. Is turning up nothing. Spoke with Fives they said there is an adaptor, which they don't have and nobody else does either. I really don't want to discharge the system entirely and make all new fittings.
    Anyone ever had this problem? What did you do?
    An other suggestions would be greatly appreciated.
    Jun 2019
    8
    Not sure if this is what you are looking for.
    I did a search on Google: 1/4 BSP Schrader Valve
    There is an eBay listing for Schrader Profile 17 Series Female Coupler 1/4 BSP Female Thread & Male Adapters
    Also, check McMaster Carr.
    Looks like they have some things available.
    Hopefully this is some help!
    If these are not what you are looking for, please provide some additional details.
    Maybe a photo also.
    BTW - That's a pretty poor response from Fives!
    Jul 2008
    Philadelphia
    2,150
    596
    493
    I did do an ebay search and did see some of what you mentioned the problem is the pressure rating on the adaptor. 130 BAR (1885 PSI) is the way above the spec on those ebay parts that I have seen. Those pressures make me pucker just a tad, call me a nervous nellie, but I want to do this as safely as possible. I will look again maybe change some parameters my terms for search.
    I was kind of disappointed in Fives, but in their defence they did say that they might have one in 50 days. I cannot be down for 50 days, so if I cannot find an adaptor plan B will placed into action. B consists of bracing the spindle, depressurizing the entire system, either modifying or making a new fill/distribution block and re-filling the system.
    Thank you for your input. If anyone has a better idea please feel free to throw your hat in the ring.
    Oct 2005
    22,010
    Aug 2019
    98
    108
    Not sure why the resistance to just emptying the system, installing a more convenient fitting and refilling. N2 is pretty cheap and readily available so that shouldn't be a factor. Also on the pressure ratings, at your nominal 2,000 psi, the force on such a small fitting is around 100#, so I wouldn't be overly concerned.
  6. Likes Strostkovy liked this post
    Jul 2008
    Philadelphia
    2,150
    596
    493
    Al I agree but the folks in charge want it yesterday and dirt cheap. If it were me I would do as you said.
    Jul 2013
    atlanta, ga
    321
    15
    253
    It sounds to me like you need a hydraulic accumulator fill/service rig. Most well-stocked Parker-Hannifen stores will have one. If not they should be able to get one to you quickly.
    Here’s a link to one, literally the first one that came up on google for a hydraulic accumulator charging kit.
    CKT-0030 : SFP Charging Kit for Bottom Repairable 3000 PSI Accumulator – OneHydraulics
    Be safe
    Jeremy
  9. Likes digger doug, doug8cat liked this post
  10. #8
    Dec 2012
    Se Ma USA
    2,237
    180
    1218
    Try here. Most fittings for PCP air rifles are rated above 4000 PSI. I have several air rifles that take a 4200 PSI charge.
    PCP Accessories | For Sale | Pyramyd Air
    Could also look here, but web site is a complete mess to navigate.
    Air Tanks For Sale Discounts for PCP (Pre-Compressed-Pneumatic) Air Gun by AirTanksForSale
    2000 psi is a common N tank full pressure (2500?) I have several 5000 PSI tanks too. They are heavy suckers.
  11. #9
    Jul 2008
    Philadelphia
    2,150
    596
    493
    Thanks to everyone for your help. I believe with all the info you guys have come up with, I have enough resources to whip this bitch. I will follow up my results.
    Thanks again for coming through, I genuinely appreciate all the resources and advise you have provided for me.
    Regards,
    Doug
  12. #10
    Feb 2004
    peekskill, NY
    27,031
    6246
    Quote Originally Posted by doug8cat View Post
    I would point out for the record that the abovementioned boundary conditions (cheap and right now) are a bit at odds with working with
    high pressure gas systems. Wear safety glasses maybe a face shield. If HP hoses come adrift they can whip you bad.
