Lapping with abrasives. What industries do it?
Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Jan 2008
    New Jersey
    453
    104
    Default Lapping with abrasives. What industries do it?
    What industries make use of lapping with abrasives and for what purpose?
    I've used it to match valves/seats in small engines and I use it to maintain my reel mowers. Who else does it and why, specifically?
    Roland
    Feb 2015
    Ohio
    526
    136
    137
    Semiconductor wafers. Super tight tolerance. Not hand lapped, done by special machinery.
    May 2003
    Lambertville, MI USA
    2,981
    1678
    1482
    Anything that has to be finished to close limits. Gage blocks are always the first thing that comes to mind. Also things like hydraulic valves, pump bodies.
    Nov 2009
    Michigan USA
    1,142
    84
    239
    anything that needs the best precision possible. Hydraulic controls, including large earth movers to jet fighter jets. Many mechanisms that need to seal quickly and totally. Ring gages. Master disc Rings. Air Gage probes. Air Bearing fits for precision gages. Chemical mixing devices. Micrometer spindles and bearings. Granet surface Plates. Large Gate Valves. Angled Seat Valves. Paint gun nozzles. Fule Injector Seats and on and on and on.
    Nov 2002
    St.Louis, Missouri, USA
    2,099
    128
    474
    Roller bearing outer races, reed valve seating areas (Curtis Air Compressor experience), RC engine cylinders, valves and seats, etc.. Too many more that I don't know about but basically anything that is very tight tolerance can use it.
    Feb 2006
    Jacksonville, FL
    154
    152
    106
    Optics. tolerances usually expressed in fractions pf wavelengths of light (roughly a few millionths of an inch)
    Jul 2004
    central NC
    2,667
    39
    722
    I've watched the guys in the Starrett factory lap surface plates to the required flatness.
    Steve
    Mar 2012
    Southern Wisconsin
    546
    71
    177
    I lap rifle barrels.
    Jul 2012
    Minnesota
    39
    27
    11
    Lapidary rock & gem polishing
    Oct 2002
    Florida
    1,229
    177
    306
    The company I retired from used a Spitfire lapping machine and grit to lap air compressor valve plates.
    Jim
  11. #11
    Oct 2005
    21,576
    Google "superfinishing"
  12. #12
    Jan 2008
    New Jersey
    453
    104
    Thanks guys!
  13. #13
    Jul 2010
    Wisconsin
    472
    367
    Quote Originally Posted by rmcphearson View Post
    Thanks guys!
    We use brass barrel laps to open up ejector pin bores in hardened mold cavities, lapping for .005" oversize pins.
  14. #14
    Dec 2008
    New York
    10,399
    2714
    optical transit, levels common to have tapered bearing. it gets lapped so female and male tapers match as well as seat that limits all weight locking the tapers together.
    its fine enough i had to thin the lapping compound as it was too thick a paste to flow. when instruments tapped side to side holds position the tapers are lapped enough. usually magic marker it up and lap til its all showing even fit
  15. #15
    Dec 2008
    New York
    10,399
    2714
    gears are often lapped in pairs
  16. #16
    Jan 2016
    New York
    295
    6
    81
    Default Lapping dowel holes
    Roland
    I always lapped the dowel holes in hardened tooling and die blocks for a light tap fit with a four ounce hammer. The closest tolerance job I ever worked on was .00005 gages. I hand lapped the special gages using a cast iron lapping plate. I still have the lapping plate. When I turned them in for inspection the inspector came to me and asked me how to measure the gages. I said your the inspector, his reply was I'll just send them back to you. So I went to Inspection with him and we measured the parts together. They passed!
  17. #17
    Jan 2008
    New Jersey
    453
    104
    Thanks again guys. Another question:
    Are the grooves in lapping plates tapered/bevelled? I've never seen one in person. I imagine they are or at least there is a chamfer at the top corner to facilitate or draw the compound up to get between the plate and the workpiece. I can't find a good image of a cross section of a lapping plate.
  18. #18
    May 2003
    5,604
    23
    813
    The grooves catch the excess compound,
    When you are lapping steel or iron the surface becomes flatter and harder, and it goes slower the further you lap as the piece work hardens.
    When you want to cut fast, you have the lap wet with oil and the compound, but, a wet lap rolls up the edges.
    So, when the work gets close, you let the lap get dry, or less wet. Then you finish and the edges get sharp, real cut you sharp.
    When lapping a piece by hand on a plate, use a figure 8 motion and rotate the piece often in 1/4 turns, and try to work the piece over the entire plate, to help keep the plate flat.
  19. #19
    Feb 2010
    ch
    3,230
    271
    448
    no idea if its lapping, but i polish my car. also industial engines used to get lapped during break in by running them with an abrasive mixed into the lubricant (engine oil), no idea if thats done today, probably not needed.
  20. #20
    Jan 2007
    Flushing/Flint, Michigan
    10,435
    603
    8469
    Carbide inserts for aluminum cutting are often lapped.
    Same with PCD segment tops.
    Sometimes this lap is free abrasive flat and other times contained.
    Is grinding with a 3000 grit wheel grinding or lapping?
    Is removing .020 from 200 carbide inserts with 120 grit diamond on a Wolters in 5 minutes free abrasive slurry lapping or charged grinding?
    And what about a Stahli that rotates the parts like a Speedfam or Woltres but uses diamond wheels for the top and bottom lapping plates?
    If you polish flutes or chipbreakers with a nylon fiber PCD impregnated brush, lapping or just polishing.
    If you do the same with a horsehair brush charged with diamond paste?
    I guess this not lapping since there is no controlled "lap".
    Bob
  21. Likes TeachMePlease liked this post
