your .o10" 5-6 long hope that is a typo the arbors for expanding yes laps no
helical lap in Frazer Mich makes laps I have used and pleased
The .010 at that length may not be accurate but they are longer than anything I have currently found, I'll check today. We had a supplier and bought a very large amount through the years but apparently they are no more.
I am very interested in what the very small OD laps you are using look like. Do you have any pictures? I am after essentially the same thing.
I've had excellent luck with helical cast iron laps, both OD and ID. You can make very straight, very round holes with these and they get better with use as long as you don't screw them up.
Helical Lap offers down to 3/64" (.047")
Internal Helical Slot Laps, Arbors and Expanders | Helical Lap and Mfg
American Lap offers down to 1/16" and I think has generally been less expensive, but I would need to check some invoices.
Internal Laps, Arbors and Expanders
Needle eye laps go down to .032", but you have to take a lot of care to not produce a bellmouthed hole.
Needle Eye Laps
Smaller than .032" and the only somewhat common option I know of would be jig grinding, which can get to just about .020".
Extrude honing is an option if you don't care about form and just need a specific flow rate:
AFM Microflow - Extrude Hone
The only other high precision, small hole, options I know are Swiss. I am scared to even ask pricing.
Schlafli make a "wire" hone system that will do down to .0015" holes:
Video - Schlafli Engineering Ltd
Microcut also has a system that uses a sort of diamond reamer that will go down to .010":
https://www.microcut.ch/technologie/?lang=en
I find the Microcut tooling interesting, as it really seems like you could run those on conventional machines for a few pieces. I really need to call them and find out.
Is anyone aware of other similar tooling?
Notice
