Large >5” hole in 24” long 3/8” aluminum plate
Results 1 to 19 of 19
    Jan 2020
    Default Large >5” hole in 24” long 3/8” aluminum plate
    I turned a 6” x 0.75” disc with a 0.375 notch (the pivot). I now need to machine a hole in one end of a 6“ by 24” 0.375” aluminum’s plate to match the notch in the pivot. I’ll need a fairly close tolerance so that the plate rotates freely on the pivot without binding.
    I have access (not mine) to a Bridgeport vertical mill and a rotary table.
    So, what is the best way to do this? BTW, I am fairly new to machining.
    Jan 2007
    Norfolk, UK
    19,047
    14549
    14658
    If both pieces are Aluminium and you want close tolerance and movement, ..I'd do a serious rethink as galling is big problem with alu on alu
    Dec 2008
    IL/WI border
    3,323
    1123
    1009
    I'm not 100% sure I understood what you need, but if it's a hole in the plate, and you don't have suitable dia. cutters (holesaw, etc.), using rotary table on Bridgeport to cut the hole with an endmill is one option. Cutting a smaller hole (with a hole saw, plasma, chain drilling, jigsaw, etc.) and increasing it with a boring head will be another option. Val-Cut trepanning tool, if you're lucky to have one, would be one more way to do it.
    Feb 2007
    St. George, Utah
    940
    477
    620
    For speed and simplicity, I'd lay it out, plasma cut, then finish with a boring head on your mill. What I'm not clear on is whether or not the hole you refer to is straight through, stepped or not through at all. Obviously, the plasma option will only work if at least part of the hole is all the way through the bar.
    Reading it again, since the 'notch' is .375 and the bar is .375 thick, a simple through-hole is what you're looking for. Right?
    A rotary table + endmill will work, but it is much more difficult to position properly and nearly impossible to get the smoothness (finish) you'd get with a boring head/bar.
    Jan 2020
    Yes, the hole is straight through. What I’m making is a spherical slide rest for a Rose engine, so the amount of wear will be minimal. But, I’m looking for a fairly tight tolerance so that the cuts I make with it are repeatable
    My one concern with the mill/rotary table combo is that I may not be able to swing the piece through 360 degrees.
    Sent from my iPad using Tapatalk
    Jun 2012
    Eastern PA
    987
    274
    448
    So the "notch" in the disc is an annular cut, at 5" diameter, leaving 3/8" of the thickness of the disc at 6" diameter?
    Dec 2008
    IL/WI border
    3,323
    1123
    1009
    Quote Originally Posted by Gbalock View Post
    If the hole is at the end of the strip, it can be a problem, indeed...
    I'd cut a smaller hole with a holesaw and finish with a boring head (boring bar inserted into the side socket).
    Langley, B.C.
    1,717
    357
    1007
    A drawing of what you're trying to accomplish would sure help...
    Oct 2005
    16,072
    Maybe you should have it waterjet cut out.
  10. Likes as9100d liked this post
  11. #10
    Feb 2007
    St. George, Utah
    940
    477
    620
    A good option. Water jet is cheap but not all that precise, and you won't get a mirror-smooth finish like you can with a boring bar. Manual attempts to polish a water-jet edge will result in deformation of the arc.
  12. #11
    Apr 2019
    Arkansas
    955
    344
    345
    I second waterjet. Find a shop with taper compensation. We have an omax with a tiltajet and can get zero taper on 3/4" thick parts and typically can hold +/-0.001 all day long.
    Sent from my Pixel 3 using Tapatalk
  13. #12
    Dec 2010
    peterborough, ontario
    130
    89
    85
    Take your largest annular or holesaw in your mill determine a secondary diameter about your required centre that will place the edge of this cutter near your needed diameter then using trig. to place a series of over lapping cut out holes inside your required diameter. Finish to size with a boring head.
  14. #13
    May 2019
    573
    148
    220
    Set the rotary up near the end of the table and swing the head over to it. Should easily be able to swing 24"
  15. Likes MichaelP, JohnEvans liked this post
  16. #14
    Dec 2010
    130
    89
    85
    Another method if you wish to use rotary table. Ream .500 hole in your plate at desired location. Turn a locating plug to fit centre hole of rotary table with a .500 spigot to fit into hole in plate. Create a series of arcs to achieve required diameter by repositioning plate about the spigot to do the full cut out. If dim. is critical do under size a finish bore.
  17. #15
    Oct 2005
    16,072
    Quote Originally Posted by as9100d View Post
    With that tolerance on the hole (from the waterjet), you could machine a ring from steel, and press fit it in, for the wear & finish requirements.
  18. Likes Gordon Heaton liked this post
  19. #16
    Apr 2007
    mays landing NJ
    522
    463
    145
    You can do this with a router and 1/2" shank end mill. Make an accurate template from MDF or plywood. Install appropriate bushing in router that will ride against the template. Put center lines on the template and the work. Line up the marks and clamp. Probably cut 1/4" deep each pass. Some routers such as Porter cable 3 HP have 5 speeds. 8000 Rpm is the slowest. Possibly a speed reducer may be okay since routers have universal motors. You will be okay at high speeds but if you can reduce the speed to 2000 RPMS it would be safer. Move the router clockwise. After the hole is cut you can clean up the hole by reverse routing , also known as climb cutting. Climb cutting tends to pull the router away from the work and usually only used to clean up the cut.
    mike
  20. #17
    Sep 2010
    Anchorage, Alaska, USA
    645
    234
    125
    That is real-world stuf.
  21. #18
    Sep 2010
    645
    234
    125
    Honestly, we are a good bunch here. So many have helped me out...
    Look, let one of us do it for you.
    That is a 5 minute program, we could save you so much time.
    If you were here, I'd do it for beer.
    Mark
  22. #19
    May 2011
    New Jersey
    615
    13
    210
    I'd just use a jig saw, alum on alum is going to grab anyways. You should make some kind of bushing ring for the shaft.
