RTH
- Jan 8, 2015
- Lambert, MT
I’ve been asked to make some parts for a lift that includes a brass nut. The shaft it lifts is stainless steel 2.5 inch acme thread. The costumer wears these out in about 5 to 6 years. They would like me to make something that will last longer.
The original nut looks like yellow brass and I think it was cast, then machined. They don’t want to wear out the shaft because that is even more problems and cost. This is an outdoor application on an irrigation gate. They have been smearing grease on the shaft for lubrication , but dirt and sand blow into the grease and make an abrasive.
I’m looking for advice on what material to make the nut out of, and what kind of dry lube might work in this application.
I was thinking aluminum bronze from a cost vs strength view.
Any advice would be appreciated.
RT
RT
