I have owned both a cold saw and a big bandsaw for quite some time. My coldsaw is a measly 350mm blade, which means it will cut about 3" material- versus the gigantic 1500mm or larger blade you would need- but its been my experience that for most metals, a bandsaw is much more efficient for cutting solid 9" rounds.
I have seen coldsaws with 30" and larger blade diameters, but they are usually track saws for cutting large, thick plate.
When I lived in California, I used to use these guys for precision plate cutting, and they have a cold saw capable of cutting 6" plate- and its a 46hp, 14 ton machine. The reason they use a circular blade for this is to hold precision on long cuts.
Precision Sawing Services for Metal - TCI Precision Metals
If I was cutting 9" round, I would use a bandsaw. As mentioned above, kerf is much thinner, and with a hefty horizontal bandsaw, you will get almost the same degree of accuracy as with a gigantic cold saw, at a lower price, with lower priced blades, and less heat affected zone. When a colds saw, even one with lots of coolant and a very slow speed, is cutting thru a big solid round, you get more heat build up than cutting the same material with a bandsaw. The bandsaw blade gets better coolant coverage, stays cooler, and keeps the material cooler as well, in my experience.
With an 1 1/2 or 2" wide bandsaw blade, you will get accuracy.
A really big cold saw like that is rare, expensive (almost always german, great quality, but pricey) and big and heavy and requiring lots of power.
Near me, there is an incredible sawing house, which mostly services Boeing and similar aerospace companies. They have probably 30 saws, including full auto slabbing saws where I have seen them cutting 1/2" thick slices off of 12" x 12" x 96" titanium bars the long way.
It is pretty telling to me that they have almost no cold saws- instead, their huge shop is full of Amada bandsaws, many of which are quarter million dollar machines- so they have the needs, the budget, and the experience to buy any saw they want to cut some of the most exotic stuff to very precise dimensions, and they consistently choose bandsaws.
