cuttergrinder
Hot Rolled
- Mar 16, 2007
- Salem,Ohio
I wish my shop had a wall of old factory windows. It just looks right.
When machining large keyways in tapered members you must account for the difference in the "m" dimension at each end of the taper. The keyway is NOT to be parallel to the side of the bore it cut on, it will be deeper at the large end of the bore. This is a bit counter intuitive and took me a minute to wrap my head around the first time I was faced with it.
Yep, if set parallel to the tapered bore edge, the key will be deeper at the small end, not the large end.
And I bet it was fun fuzzing a smidge out. Good times. The long keyways on the planer were done with a long ~6" diameter bar of which one end was mounted to the floor on top of a post bolted to a base set flush in the concrete with a pivot at the top of the post. The other end was mounted to the planer head. Tool was mounted in the bar.
Notice
