lathe bed shaking as hell.
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Dec 2016
    GREECE
    39
    6
    Default lathe bed shaking as hell.
    As the title,my lathe at least 2 weeks,the bed of my lathe in every cutting,or finishing work, has started to shake a lot .. can someone tell me what's wrong;
    Feb 2006
    Indiana
    12,064
    464
    3225
    A rapidly rotating part is out of balance. The lathe is not anchored to a solid floor.
    Larry
    Feb 2007
    St. George, Utah
    548
    126
    269
    Anything loose? Cutting insert, gibs etc?
    I'm reading between the lines a bit, but I get the impression it only vibrates while cutting, and that this is a new problem, right?
    Dec 2016
    GREECE
    39
    6
    Quote Originally Posted by L Vanice View Post
    Larry
    i check everything and all the parts are tight anf fit between of them..
    Jul 2014
    Ontario, Canada
    926
    664
    606
    Post a video, if you can. Host it to Youtube or Vimeo, link it here. Otherwise we're all just p*ssing in the wind with the guesses.
  6. Likes michiganbuck liked this post
    Dec 2016
    GREECE
    39
    6
    Quote Originally Posted by Gordon Heaton View Post
    cutting and turning jobs.Yes a new problem,find home....
    Jul 2007
    Orlando, Florida
    662
    72
    336
    Quote Originally Posted by ΓΡΕΖΕΡΜΑΝ View Post
    Is it shaking just when you are cutting, or when ever the spindle is turning?
    Does it shake as much at low spindle RPM as at high spindle RPM?
    CarlBoyd
  9. Likes michiganbuck liked this post
  10. #8
    Jan 2005
    CANADA
    Saskatchewan
    9,609
    1188
    3293
    One jackscrew on the lathe's plinths has come off its floor pad? A drive V belt might have lost a chunk? The belt tension is too loose and a harmonic vibration gets going?
  11. #9
    Jul 2005
    Cottage Grove, MN 55016
    6,488
    3467
    3842
    When you check the V belts Also check the pulley on the motor. Not knowing what brand lathe or model makes it hard to help. You have the machine setting on the floor tight and aligned and leveled? How long is the part your turning? What diameter is it? How far is it sticking out the chuck? Are you using the tail stock? Did you CRASH the machine like running the compound into the chuck? Do you have a dial indicator you can put on the outside of your chuck and see if the chuck in running round? If you crashed the machine you may have bent the spindle if it is a small Asian lathe. Take some pictures if you can't do a You Tube.
  12. Likes ΓΡΕΖΕΡΜΑΝ liked this post
  13. #10
    Dec 2016
    GREECE
    39
    6
    I will try it the next time
  14. #11
    Dec 2016
    GREECE
    39
    6
    Today ,i see in one of my turning jobs,that the bed of the lathe is not shaking ,but the cariage is like to dance end it is distracting all the other parts..
  15. #12
    Jun 2012
    Idaho
    2,985
    1623
    1918
    Start with the basics
    What brand and model of lathe ?
  16. #13
    Jul 2005
    6,488
    3467
    3842
    You know how to sharpen your tool bit don't you? If your using an insert check to be sure its right side up and in the centerline of the part. Look and see if there is a tapered gib missing or lose.
  17. Likes ΓΡΕΖΕΡΜΑΝ liked this post
  18. #14
    Mar 2013
    Surbiton, surrey, UK
    1,236
    1364
    731
  19. Likes Richard King, scadvice liked this post
  20. #15
    Apr 2004
    Modesto, CA USA
    5,763
    858
    This guy has posted here before. I think his lathe was Polish or Russian. Give him a break on his English it is much better then my Greek.
    Bill D.
    I am thing everyone this is some make believe joker we have here.[/QUOTE]
  21. Likes Mtndew liked this post
  22. #16
    Jun 2012
    Michigan
    3,705
    3205
    2141
    chreiazómaste perissóteres pliroforíes gia to michánimá sas. Eínai epípedo?
    Boreíte na dimosiéfsete éna vínteo YouTube gia to próvlimá sas?
  23. Likes ΓΡΕΖΕΡΜΑΝ liked this post
  24. #17
    Oct 2005
    10,248
    17320
    5352
    Are you working a large radius, in a corner ?
  25. #18
    Dec 2016
    GREECE
    39
    6
    no,theese parts are all tight..
  26. #19
    Dec 2016
    GREECE
    39
    6
    no at that point of the work..smaal diameter piece.and the strange thing..is just cast iron.
  27. #20
    Dec 2016
    GREECE
    39
    6
    its a Russian lathe,medium duty.I check it in manual,but I cant find somethimg to help me.
