lathe chuck for holding on milling machine
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Feb 2017
    525
    8
    170
    Default lathe chuck for holding on milling machine
    Just curious whether any of you have used a lathe chuck (mounted to table) to hold a cylindrical work piece in vertical position for milling?
    Sep 2015
    CANADA
    Ontario
    106
    52
    43
    Yes, have done so many times. We just ordered 4 6" chucks to mount on a fixture plate for this purpose on our CNC.
    May 2002
    South Central PA
    13,887
    2432
    3676
    Yes. This is a 12" chuck holding an 8" part. Atlas workholding makes a chuck specifically for mill use, I just use standard lathe chucks.
    Dec 2014
    Arizona
    369
    39
    63
    Yep, works good. Use them for vertical, horizontal, and angular workholding. Use them on RT's and angle plates as well. For a lot of stuff a good 6" reversable 3 jaw scroll Buck chuck works good, but depending on work I'll use up to 12" chuck on the mill. You can make yourself a nice adapter plate, you don't have to have one, but they make things much easier = quicker.
  5. Likes Bobw liked this post
    Feb 2017
    525
    8
    170
    Awesome feedback! Next up is an adapter plate!
    Dec 2002
    Benicia California USA
    8,350
    1947
    2685
    Bison makes a nice adapter plate for their flat back lathe chucks.
    I have a dedicated 8" chuck on that base for mill work....Not so important to have a "trick" chuck here if its mill service.
    On the mill you center on the part so even a chuck with run out is fine so long as the jaws are not bell mouthed....
    Get a chuck with two piece jaws so that you can fit soft jaws and bore true for work if needed....
    Also mount my front line lathe chuck on the mill if i have a turning job where i wish to be true to the turned part...
    My primary lathe chuck is a 200mm Schunk.."Rota-G" .D1-6.mount....simply remove the chuck, unscrew the cam pins (i number them and put a mark where the pin meets the chuck back to make refitting easier.).. and put the chuck directly on the mill table, couple of hold downs and you are good to go....
    Cheers Ross
    Feb 2017
    525
    8
    170
    I have a spare 10" Rohm chuck, brand new, that'll work nicely for this....
    Your idea of moving the chuck from lathe to mill for retaining accuracy is great! I have very similar lathe chuck setup, DIN 55027/5 mount so same deal to unscrew the cam pins.
  9. #8
    Apr 2004
    Modesto, CA USA
    7,462
    1308
    Most rotary tables have a nicely machined center hole that can be used to locate a chuck with a mounting plate and a stub arbor setup.
    Bill D
  10. #9
    Feb 2017
    525
    8
    170
    Good idea.
  11. #10
    Jan 2007
    Norfolk, UK
    19,855
    15294
    15571
    Quote Originally Posted by drcoelho View Post
    Cheapskate time
    If you need a largish dia disc of high quality CI, look for a car engine flywheel at the recyclers etc etc
  12. Likes tim9lives liked this post
  13. #11
    Aug 2010
    Minnesota USA
    283
    55
    If you notice the photo in #3, they just clamped the chuck to the table. No back plate. Two or three mill clamps. Been doing this for a long time.
  14. Likes Mtndew liked this post
  15. #12
    Jun 2012
    Michigan
    5,196
    4770
    3146
    Quote Originally Posted by Mud View Post
    What do you have on those jaws? Grippers?
  16. #13
    Sep 2010
    Oklahoma City, OK
    4,932
    881
    2061
    An 8" flat back is E1 on my Fadal. I do lots of round stuff.
  17. #14
    May 2002
    South Central PA
    13,887
    2432
    3676
    Quote Originally Posted by Mtndew View Post
    Yes, screw in carbide tipped grippers. Carr Lane I think.
    Y
  18. #15
    May 2011
    southern in.
    1,514
    2015
    406
    I keep a 8" 3-jaw with two 1/2" holes in the body just for the mill. It is a flatback I picked up at auction.
    JH
  19. #16
    Jan 2011
    Fairfield, PA
    398
    201
    196
    I have a 4" chuck mounted on a ground plate for small parts. Just stick it in the vise.
    Old 10" W&S A2-8 mount. No mounting plate. Run two studs through the chuck body directly to the tee nuts.
    Have soft jaws for the 10" and two 6" chucks. Easy to interpolate/bore the jaws.
    Bill
  20. #17
    Apr 2012
    Garnet Valley, PA
    91
    12
    6
    Quote Originally Posted by Bill in PA View Post
    Bill
    I use one of these
    RDX Horizontal & Vertical Indexing Fixture
  21. #18
    Mar 2019
    UNITED KINGDOM
    207
    40
    Yep, used to use a collect chuck to mill square heads on pins, sets of 100 on a semi-auto CNC
  22. #19
    Nov 2019
    FINLAND
    76
    28
    8
    It seems someone else has been wondering this as well. I had worn 10" chuck with camlock D8 backing plate that I decided to instead scrapping use it on my mill for round stock work holding. However was wondering that does this make any sense that maybe V-block would do the same? Would it be as rigid.. Also was thinking that the chuck is quite heavy that is it bad for the linear quide rails in the long term. What do you think?
    One benefit I find is that the work offset will always stay the same...
  23. #20
    Mar 2011
    Geneva Illinois USA
    6,439
    2817
    2521
    With a "V" block you will have recenter when changing parts. Not so with a 3 jaw chuck. If you are concerned about weight, take the chuck off when you are not using it. I have left a 6" on my mill frequently, but it cuts down on where I can put stuff. When that happens, off it comes.
    Tom
