Lathe - HSS micro cutoff tool?
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Aug 2007
    colorado
    108
    9
    Default Lathe - HSS micro cutoff tool?
    anyone recommend a decent tool that takes the sliding HSS blades in a very small size 1/16" wide, 1/4 to 3/8" tall. All the ones i see are cheap imports, and not a huge fan.
    reason is i do a lot of expensive plastic, Vespel, PEEK, trying to reduce waste. Can go to 3/32 if need be. Currently have this, made in India, not very good
    I've gone to both Dorian and Aloris and their web-sites are really non-functional : (
    thank you for any advice
    Aug 2007
    colorado
    108
    9
    I found this one from Grizzly, unlike the one i have, at least the blade is fully supported. Anyone try this yet?
    Jan 2007
    Norfolk, UK
    18,930
    14434
    14498
    Look for Swiss lathe or sliding head lathe tooling.
  4. Likes digger doug, Dualkit liked this post
    Sep 2010
    moscow,ohio
    5,936
    579
    1895
    Probably not what you want hear, but IMO for your purpose you would be far better off to grind from square HSS blanks, you get the thinness you want in a much more stable tool that doesn't require a special holder.
  6. Likes Thunderjet, dcsipo, JDennis liked this post
  7. #5
    May 2017
    FINLAND
    1,775
    496
    812
    Quote Originally Posted by draganm View Post
    How large diameters you need to work with?
    Carbide parting inserts and tooling are available down to 1.5mm if 15mm reach is sufficient.
  8. #6
    Jun 2019
    Missouri
    138
    64
    91
    Quote Originally Posted by iwananew10K View Post
    I do exactly that.
    .020 x .188 tall and about .300 reach.
    Works well for plastics and carbon, even aluminum is ok with some lube.
  9. #7
    Jan 2007
    Norfolk, UK
    18,930
    14434
    14498
  10. Likes digger doug liked this post
  11. #8
    Sep 2010
    moscow,ohio
    5,936
    579
    1895
    Never used this, but some seem to like them and at least it's high quality.
    maybe something here will appeal to you-
    Cutoff and Grooving
  12. Likes Nmbmxer, sandiapaul liked this post
  13. #9
    Oct 2010
    Dewees Texas
    2,395
    27
    654
    I think Empire still has some and will custom make them for you. I have had them make 2 and copied their patterns in making several more from A6 tool steel. I have made both styles, the Luers patent style with the cam locks and the kind with the wedge. The Luers style will make indentations in the bottom of the blade that have to be honed out as the blade wears and is sharpened. The wedge style is more trouble free but takes a little more thought to make them.
    Limy mentioned Somma, if they have what you need it is good American made stuff. Never asked them to make custom but that might be worth a shot also.
    OK, I went back and looked at the original post and you are looking for 3/8 tall blades. I have ever seen them that short, the 1/2 tall blades I mostly use are available in widths down to .040 and Somma has them in solid or brazed carbide as well as several grades of HSS.
    Not sure where a 1/4 or 3/8 height would save anything, it is the width that will waste material.
  14. #10
    Aug 2007
    colorado
    108
    9
    thanks for all the replies guys, I'm not averse to grinding my own tools, do it all the time, but for this really want something i can sharpen in 2 minutes and use for years without re-profiling the blade.
    iwananew10K I think this one for 85 bucks is exactly what i want,
    thanks
    made here with pride.
    Kit #28 3/8 inch Parting Tool
    need to choose between the 3/8 or 1/2" and make sure either one accepts the .032 blade option.
    btw, it's amazing how hard these things are to find, even with google it's like looking for Unicorn poop
  15. Likes Limy Sami liked this post
  16. #11
    Feb 2005
    Akron, Ohio
    747
    314
    107
    I have their cut off tool and it works very well. 1/6" and 1/32" blades.
    https://www.arwarnerco.com/
  17. #12
    May 2019
    Arkansas
    146
    17
    83
    I may have an OLD Starrett thin HSS parting tool laying around. I'll check.
  18. #13
    Mar 2009
    5,160
    97
    950
    I bought a few Micro 100 cutoff tools. The HSS shattered where the carbide was attached to the HSS blank. That was parting off a 1" diameter aluminium piece at about 350 rpm.
    I'm using my old HSS blanks. Have not bought a new blank yet because all the stuff they have in stock is chinese junk.
  19. #14
    Virginia
    27,613
    7561
    8600
    Close, but slow cigar. for all the grinding from a square blank will demand.
    What you want is salvaged power hacksaw blade lengths. Big and deep ones. Worth chopsawing up NEW blades, actually. They are as little as five bucks and up, each, so many PHS having gone-over to coldsaws or bandsaws.
    Thin section across, plus very DEEP (that's important..). Already that shape..
    Very little grinding needed to put what you need for your particular material into the working edge. Fast and dirt-cheap to have "many", each ground for different plastics, even shiney-wood and "real" wood. Steel and bronze, too... if you have the coolant for it and a bit of patience.
    Provide FULL support clear out to directly under the contact edge - or even a tab beyond.
    About as thin a waste-line as one can sustain without egg-walking to hand razor-saw the material off.
  20. Likes Limy Sami, tim9lives liked this post
  21. #15
    Jan 2007
    Norfolk, UK
    18,930
    14434
    14498
    Warning to Thermites M/C hacksaw blade idea, …..some are Bi metal - as in a strip of HSS welded to the edge of a carbon steel blank.
    I know for sure Sandvik blades are mainly Bi-metal
  22. #16
    Norfolk England
    2,284
    2630
    1695
    Default Circular part off tools
    In post 7 Limy mentions circular tools. You need to look in to this,a heck of a lot of tool,just re-grind the top and away you go again.
  23. Likes Limy Sami liked this post
  24. #17
    Virginia
    27,613
    7561
    8600
    Quote Originally Posted by Limy Sami View Post
    Easily have seven or eight varieties counting pitch and gullet shapes as well as makers-of amongst the 50-60 18" X 1 1/2" - or Metric equivalent - I laid by for the Kasto whilst they were cheap and plentiful. There's a TON of stuff they can be "donors" for, worn or new, besides sawing.
    Pretty obvious the side with the teeth is the HSS part on the welded ones. MOST hand HS blades are Bi, gar-ron-teed side stresses abound. PHS, with precise guidance, not as often, but yazzz... pays to pay attention...
  25. #18
    Jun 2012
    Michigan
    10,184
    3456
    3639
    If having a surface grinder you might experiment with putting on a top radius to a parting blade so the cutting edge has the effect of a positive rake angle. We made parting blades with a 1/4" to a 1" radius on the top edge. Some we made with this scallop and the exit angle going to one side with wishing chip ribbon to go a certain direction.
    Yes some guys do this by hand on a bench grinder to a blade or tool bit.
    Some parting blades we made with side taper going down both side of perhaps 1 ot 2 degrees.
    Others we made with flat sides bit wider at the top to the width needed, so perhaps the sides below the tool with would be flat ground undercut .005 or so.
    Being exact square to the part and at the best position to center is very important.
    I used a cold air gun for some grinding..that might help for plastics parting.(?)
    Cold Air Guns, Nozzles | Industrial Spot Air Cooling Equipment
  26. #19
    Apr 2005
    Beaverdam, Virginia
    7,430
    698
    3510
    I have some that are only .040 wide, but they don't support a very deep depth of cut. Even the .062 wide will only cut off 13/16 stock.
  27. Likes TeachMePlease, Limy Sami liked this post
  28. #20
    Jan 2007
    Norfolk, UK
    18,930
    14434
    14498
    Quote Originally Posted by Dualkit View Post
    I agree, that's often the problem with them Dual, ...BOTOH the OP didn't say what dia' he wanted to part.
