Had a question for the indexable experts here.
Does solely the size (I am talk IC size) of an insert have an inherent bearing on the cutting requirements of the insert?
For instance, two inserts:
CCMT431
CCMT321
(the difference in thickness is only because I am not aware of any CCMT331 inserts)
If price was equal, and the DOC did not exceed 3/16", would there be any reason to use the 3/8" IC insert over the 1/2"? Does chipbreaker/feedrate/DOC optimal geometry change with IC size? Perhaps a more simple way of stating: If a low HP lathe works well using a CCMT321, a .050" cut, and a .010" feed, would you expect the same performance from a comparable CCMT431 on that same lathe? Or, would the CCMT431, even with the same nose radius, generally have a top geometry that would require a deeper cut, or a faster feedrate to get the same surface finish and chip generation quality? Further yet, perhaps this "matched" performance is possible, but do manufacturers simply assume that a 1/2" bit will be used in heavier operations, and therefore make the cutting surfaces accordingly?
I have a lower HP machine that would likely work well with some of the smaller positive geometry tooling. However, I have a reason to stick with (physically) larger tooling that I currently use with a larger higher HP machine. What I don't want to do, is end up with inserts that are too big (IC size) to make some of the more modest cuts I plan to make on the this machine. If I need to go to a 3/8" or even 1/4" IC insert, the deal is done. If I can stay with 1/2" IC and still get the smaller cuts to work equally well, I have reason to do so.
Thanks for the info.
CCMT431
CCMT321
