windsormw
- Dec 11, 2006
- The corner of Hill & William
Hello Practical Machinists ,
Its been a while since I have posted on this board but am in hopes you folks could help me sort out my lathe issue . I bought a big dirty Ebay lathe a long time ago , got it running a while back and haven't used it a whole lot and what little use I have had has been short pieces .
The issue : It cuts on a .03 taper at 3 feet !
My findings : I clocked up the ID of tail stock at head stock ( +- .0005 ) , indicated bed rails with carriage but still this big old girl is in and out like a fiddlers elbow .
- placed a long piece of material in , took parallel cuts at the ends on piece and adjusted tail stock to suit . Still the dia. is not constant .
I am up to my ears in local work - I would like to hear your thoughts . BTW its been machine leveled .
todays results :
All I have is a 6" precision ground bar thats approx. 3 " in dia. & chucked it up in 4 jaw , indicated both end diameters and face with interapid then did a carriage sweep along z axis . I then loosened bolts on head stock and adjusted it to to give me a less than .0005 along Z axis .
Next I brought tail stock in and indicated it , adjusted tail stock to suit horizontally and added .029 shim to to achive +- .0005 sweep on ID of tail stock .
After that I placed a 3 ft bar in lathe and made a cut . Still its cuts on almost a .025 taper . If I adjust tail stock over I can achive a +- of .008 over 3 ft .
I leveled my lathe with a 12" starrett machinist level and a 10 " Mitutoyo master level but the part where the tail stock needed .029 to come onto head stock center tells me that this old girl has alot of miles on her .
your thoughts
Scott
todays results :
your thoughts
Scott
