I need some advice on how to make the following part. Since I hate lathes.
Fairly simply part, it's a adapter for an axle (od is 130mm). It contains some bolt holes at the front.
How should I make it in the (conventional) lathe?
I was thinking about turning the front and od.
Turning the part around in a 4 jaw chuck and turning the other side?
Will this be accurate enough or should it be done in 1 op?
