Bill D
- Apr 1, 2004
- Modesto, CA USA
Harrison M300. The threading quick change gearbox has one knob which has 8 positions. It can be hard to get into some of the positions. I have run solvent in the box and drained/ refilled. which has helped. These gearboxes are known for gunk building up on a cam which shifts forks to slide gears around. This cam is what the knob in question moves.
I have had the apron and headstock open and their gears etc look very clean just a slight sludge on the bottom is all. What I can see of the threading gearbox ,from the oil fill, looks the same to me.
I took off the gear that connects the QC box to the headstock gearing. Now the qc box changes fast and smooth with no sticking at all. Seems like I do not need to drop the QC box since it is fine by itself? Something is hanging up when it is connected to the main gearing but I do not see how.
All this shifting is done with the motor off and just rolling the chuck as needed. I tried with the motor running and it did not free up anything. Once I pulled the gear I did rotate the input shaft as needed to shift the qc box. I will have to check all the idler gears for junk in the teeth or something now.
Bill D.
The Harrison Yahoo group has nothing on these symptoms
Bill D.
