Hi guys. Long time reader, first time poster. I feel real stupid needing to ask but i can’t wrap my head around this. I’ve just started playing with a small lathe, making threads. My gearing is good, tpi is correct (and checked), compound at 29, tip of the tool (carbide insert) is in center, but the two times i have tried the same thing has happened. This is aluminium, so just running slow and steady, but after the first 2-3 passes, taking very shallow cuts, the carbide insert (i thought and still think is a threading insert (60 degree)) starts eathing into the shoulders of the threads, so i end up with a shallow thread i can check tpi in, but the more passes i take, the thinner/smaller the diameter gets. Have run a 25mm down to 23-23.5, should be deep enought to get some real threads.
