Bill D
- Apr 1, 2004
- Modesto, CA USA
This is a real simple question about using a toolpost grinder on a lathe to make a taper. Should the grinding wheel contact point be on the centerline similar to a cutting tool or does it not matter? For cylinder grinding I do not think it matters but for taper grinding does the geometry vary the angle if it is not on center?
Bill D
Bill D
