Lathe toolpost grinder centerline orrientation
Results 1 to 3 of 3
    Apr 2004
    Modesto, CA USA
    7,753
    1390
    Default Lathe toolpost grinder centerline orrientation
    This is a real simple question about using a toolpost grinder on a lathe to make a taper. Should the grinding wheel contact point be on the centerline similar to a cutting tool or does it not matter? For cylinder grinding I do not think it matters but for taper grinding does the geometry vary the angle if it is not on center?
    Bill D
    Aug 2009
    AUSTRALIA
    532
    116
    73
    I believe it will just like a lathe tool. Otherwise the sides of your taper won’t be straight.
    Sep 2005
    Oakland, CA
    2,733
    414
    796
    #2 is correct- the contact line of the grinding wheel must be on center to reproduce the taper correctly.
  4. Likes jims liked this post
