Lead screw bearing/support for Atlas V36 lathe 6 inch
Results 1 to 11 of 11
    Sep 2016
    CANADA
    Ontario
    47
    6
    Default Lead screw bearing/support for Atlas V36 lathe 6 inch
    Hello there.
    I have Atlas V36 lathe with broken leadscrew bearing on right hand side. Previous owner made some fixture out of big door hinge (!!!). It works but looks terrible and feels wobly.
    Looking for measurements or dimensions or drawings for leadscrew support on 6 inch Atlas v36 lathe. Specifically I am interested in two critical measurements: distance away and distance down for shaft bore center line from mounting surface. Plan is to 3d print it first and than to cast it from aluminum or brass
    Thanks a lot.
    Oct 2005
    20,702
    Quote Originally Posted by geshka View Post
    Hello there.
    Thanks a lot.
    Machinery Discussion Guidelines
    "In before the locky poo".....
    Sep 2006
    Stillwater, Oklahoma
    1,691
    132
    942
    Hello there.
    Thanks a lot.
    There is or was a yahoo group specifically for those lathes and though yahoo groups has died, there might be a follow on if you search.
    You should also check out the Home Shop Machinist discussion forum which does permit discussion of that machine.
  4. Likes digger doug liked this post
    Feb 2007
    St. George, Utah
    1,232
    792
    836
    You can measure those distances close enough yourself. Move the carriage all the way toward the tailstock, lock the half-nuts and remove the existing mounting bracket. The leadscrew will float to the best position for the bracket. Use a square, block rule etc. and get the measurements you need.
    Sep 2016
    CANADA
    Ontario
    47
    6
    Oops. sorry.
    Sep 2016
    CANADA
    Ontario
    47
    6
    Quote Originally Posted by Gordon Heaton View Post
    ... get the measurements you need.
    yes, this is backup plan. Thanks
    Feb 2004
    peekskill, NY
    26,414
    5934
    Southbend did it one better. The right hand leadscrew support is overbored, and when the carriage is located nearby, they poured babbit metal into the support, to make it real close.
    Don't cast it, machine it from a lump of brass or aluminum. It only has to be close, the leadscrews are not terribly rigid.
  9. Likes muckalee liked this post
  10. #8
    Sep 2016
    CANADA
    Ontario
    47
    6
    Quote Originally Posted by jim rozen View Post
    That is clever. I still don't have this technology and I don't have babbit... Lump of aluminum is easier to obtain
  11. #9
    Feb 2004
    peekskill, NY
    26,414
    5934
    Best part is the SB parts manual for that bracket shows a weird little prismatic block. With a part number. It's the block of babbit metal!
  12. #10
    Virginia
    18,047
    7561
    11428
    For an @las? ISTR a Carter "Model N" lawnmower side-draft carb stripped of throttle shaft & butterfly plate has a bore about the right size?
    Ignorant pine will do, actually.
    He did say "@las?"
  13. #11
    May 2003
    5,274
    21
    623
    Really termite! One would think you would go off on your BS 50" Niles lathe story here, the spring cuts termite...all the spring cuts you could ever hope for!
    Your certainly are full of shit no matter the subject.
