Leak/Catch Trays
Results 1 to 13 of 13
    Jan 2011
    UK
    5
    Default Leak/Catch Trays
    Hi Guys,
    What are people doing to help keep their shop floor clear of leaking coolant and hydraulic oil from older machines? Anyone using steel fabricated trays for the machine to sit inside?
    May 2003
    Iowa
    10,490
    3616
    4281
    When I was in automotive, we had under every machine. IIRC, most were 12ga and about 4" larger on each side than the machine. They were "supposed" to get cleaned out once a shift. Last place I worked at, they just fixed the leaks.
    JR
    Jul 2009
    Peoria, IL
    11,738
    51
    9007
    Mine is made from concrete. It's about 8" thick. Covers the whole shop...
    Oct 2005
    17,769
    Are the machine tools anchored down or just sitting on the floor ?
    Virginia
    31,331
    7561
    9830
    Quote Originally Posted by ewlsey View Post
    Cheater.........
    Jun 2001
    lancaster,ohio.43130
    935
    18
    141
    I bought a aluminum foil cheap cooking tray and cut the sides down to 1/2" high to slide under My lathe. Cost was around $1 and the bank has since recovered.
    Nov 2011
    Idaho USA
    203
    40
    I like cookie sheets. I put oil absorbent pads in them.
    Nov 2007
    marysville ohio
    9,879
    2819
    6585
    Quote Originally Posted by mark costello View Post
    I need one 5' x 16' for my lathe, do they make them that size?
    May 2008
    Minnesota
    724
    360
    258
    I had one made for my horizontal band saw. It's got a little tiny hydraulic leak. But the pan has been much more useful catching the coolant that doesn't make it back into the sump. And for providing a place to put cut offs at an angle so the coolant can drain off.
    I was going to make one. But the neighbors fab shop made it for less than I could think about. 14 gauge steel. 64" long x 34" wide x 3" deep. Had them bend and stitch weld 1/4" steel rod around the top so nobody would cut their ankles on it. Material: $72.45 Labor: $112.50
    Jan 2005
    CANADA
    Saskatchewan
    10,238
    1396
    3696
    I had a large shallow tray fabbed up for the turret mill, about 3 x 5 feet. Locked the knee in place, removed the anchor bolts in the jack screw base, and wound that up a ways, then slide the pan underneath, lowered the screw base back down and bolted it back down. I had to drill the bolt pattern through the pan of course.
    This arrangement is handy because it gives you a toe space to work around. No way would I want that pan on the floor and be tripping and stubbing against it.
  11. #11
    Jun 2001
    935
    18
    141
    Hey Moonlight, If I only could get a turkey that big.................
  12. #12
    Virginia
    31,331
    7561
    9830
    Quote Originally Posted by moonlight machine View Post
    Country as once built over 2700 441-foot long Liberty ships in four years oughta still have SOMEBODY as can make a piddly little crumb tray for a toaster oven...
  13. #13
    Oct 2005
    17,769
    DonJohn shipyard in Erie still has the drydock up & running for the 1000 footers....
    Just sayin'
