RC99
- Mar 26, 2005
Got a chap in Perth with an Elb Schiff surface grinder with problems, anyway I will let the email I got do the talking, if anyone has any ideas on what to do or who in Oz might be able to help..
O.K, RC .. here's a curly one for ya .. I got a mate rebuilding an ELB-Schliff surface grinder .. and the spindle rear bearing is farked beyond belief.
Where do you get a replacement bearing for something like this?? .. at a cost that doesn't need an overdraft??
(It's the bronze bushing to the left of his hand, in the first pic. It's a multiple-split, steel-backed bronze, tapered bushing that is tightened on the spindle, by the worm-drive helical gear you can see, that is threaded onto the steel section of the bushing. When the gear is screwed up, it pulls the split bushing tighter in its tapered hole, to tighten the clearance on the spindle. The RH side is a similar deal, but that bushing is O.K.).
This thing runs on such tight tolerances, it uses kerosene as a lubricant for the bronze bushings. The clearance is currently about 1-1.5 mm, when screwed right up.
I find companies in the US and UK rebuilding entire spindle assemblies, and selling new spindle assemblies .. but the freight alone would be worth as much as the grinder.
We're looking for a local repair option .. or some crowd that supplies parts for ELB-Schliff. You got any ideas??
