rbertalotto
- Dec 6, 2008
- Dartmouth, MA
A few years ago I converted my 14" wood bandsaw to cut metal. I used a 3/4hp, 1750rpm, 90V DC motor to slow down the blade SFM. It has worked well on aluminum and thin steel up to about an 1/8". But the blade speed of about 500 SFM is too fast for anything thicker and wears out blade very quickly
I decided to upgrade it with a gear reducer
From Surplus Center I bought a right angle 50-1 gear reducer
Using a 5" pulley on the reducer and a 3" pully on the bandsaws 14" wheel I get my SFM down to 238 which should be right where I need it.
Problem is I now get belt slipping. No problem with torque. but the 3" pully slips badly. I do not have room to increase the size of the pulleys.
Therefore I want to go with chain drive and be done with it.
A #40 chain has strength of 3700 pounds. Would this be strong enough for my application or is this overkill? I have zero experience with chain drive other than motorcycles and bicycles.
Any help or advise is appreciated
