Lehmann Hydratrol 34x372 need manual
Results 1 to 14 of 14
    Jul 2015
    Utah
    12
    Default Lehmann Hydratrol 34x372 need manual
    I have a rapid problem, it will move away from the chuck but not towards. Anyone know anything about this?
    Jul 2004
    Houston, TX USA
    30,433
    Have the manual for the 25" serial 5886 - I'll scan the RT page in the morning
    First thing that page cautions you about is having the drive motor turn the right way - has to make RT screw rotate CW when viewed from tail stock end
    Wrong way rotation causes the hyd. direction controls to not work right
    Here is that scan. A more "readable" version can be emailed if you want to private message me that address. Do put something in the subject line like Lehmann
  3. Likes 4GSR, djensen liked this post
    Jan 2005
    Victoria, Texas, USA
    4,114
    2333
    1046
    If that doesn't correct the problem, the two pistons that direct the hydraulic oil flow in the control handle on the carriage handwheel may have worn ball checks in them. Last, could be the clutch linings are worn completely out to where they won't engage the R.T. nut for pushing the carriage toward the chuck. Ken
  5. Likes djensen liked this post
  6. #4
    Jul 2015
    Utah
    12
    Thank you, this explains how the system works, quite ingenious. I'm a Doosan tech and get tasked to repair off brand machines for customers often. I don't want to do exploratory surgery, and run the cost through the roof, because of a simple adjustment. I actually have two Lehman lathes with this problem from two different customers. Keep the spindles turning! Thank You again!
  7. #5
    Jul 2004
    Houston, TX USA
    30,433
    PDF sent of manual - maybe it will be useful. Pretty slim at 12 pages
  8. Likes JekaMandra liked this post
  9. #6
    Feb 2020
    RUSSIAN FEDERATION
    Hello! Suddenly i have bot this toy.....
    YouTube
    in very poor condition. If you dont mind please send me manual too....
    Thanks a lot.
  10. #7
    Jul 2004
    Houston, TX USA
    30,433
    Нужен адрес электронной почты
    :d
  11. #8
    Feb 2020
    RUSSIAN FEDERATION
    [email protected]
    Thanks a lot again!
  12. #9
    Jul 2004
    Houston, TX USA
    30,433
    Quote Originally Posted by JekaMandra View Post
    [email protected]
    Thanks a lot again!
    Your toughest job will getting the oil to do all those things just right
    Lehmann thought LAPPING was the way to get gear teeth just right
  13. Likes 4GSR liked this post
  14. #10
    Jan 2005
    4,114
    2333
    1046
    Always wondered if those gear lappers they built and used ever did a good job of lapping gear teeth on the headstock gears???
    The picture of the oiling system shown above, I have the original artwork that was used to shoot the picture used in publications. Saved from a dumpster dive many years ago at Drilco in Houston. Ken
  15. #11
    Feb 2020
    RUSSIAN FEDERATION
    Hello!
    Where is a serial number may be on a lathe???? cant find it. Interesting a year of build my toy.....
    Thanks.
    Have bot oil. 80 litres of Mobil DTE medium... i change oil filter on a external unit.... repair same gears shift device...
  16. #12
    Jan 2005
    4,114
    2333
    1046
    Lehmann stamped the serial number in two places that I know of on the older lathes built before 1976. Anything newer, have no clue where the s/n is stamped. On the older lathes, it's generally stamped at the tail end of the bed between the flat and the vee. They also stamped it on the top side of the saddle at the front. Find the s/n and post. One of us can provide a approximate year of build for you. Ken
    Edit: Mobil DTE mediun should be just fine. Do not run any oil heavier than that.
  17. #13
    Feb 2020
    RUSSIAN FEDERATION
    Quote Originally Posted by 4GSR View Post
    Thanks. Very. I already got mobil dte. My unit was not running all USSR period on a good oil fact. unknown regular very poor black not clear oil 40 litres was in. oil filter - YouTube . It still works!
    YouTube
    in my opinion lathe wow2 years....
  18. Likes 4GSR liked this post
  19. #14
    Jan 2005
    4,114
    2333
    1046
    Nice to see them old Lehmann's still in service! Those were some sweet running lathes for their time! You could shift speeds without stopping the spindle except for back gear and reverse!
    BTW- The serial number for that size lathe 32"-36", starts with a "C" followed by a three digit number. Example "C123".
    Ken
