Levelling a machine on four feet
Results 1 to 10 of 10
    Feb 2018
    NEW ZEALAND
    19
    Default Levelling a machine on four feet
    Both my lathe and milling machine sit on stands with four adjustable feet. I am having to move them again and the last time I levelled them it was a painful experience, with the end result being more luck than judgement.
    Without just building new stands with three levelling points; is there actually a correct method of levelling off four points?
    Mar 2006
    PHILIPPINES
    2,494
    572
    812
    Leveling machines is just an art perfected over time with experience. Four pads is just a matter of getting them on the ground and starting off with a 6" level then fine tuning with a 12" master level. Only having four pads it sounds pretty small so jacking the screws shouldn't be too hard.
    Should have come help me level my Johnford SDMC (Junkford) with 164 pads!
    Mar 2005
    Kansas
    7,578
    438
    3494
    To level 4 pads put your level on a diagonal between 2 pads, then do the other two to remove rock.
  4. Likes mike 44 liked this post
    May 2003
    4,631
    328
    Hardinge, recommends adjusting with 3 feet, then adjusting the right rear foot, to keep the machine from rocking. But, the machine is balanced that way, may not work with others.
    Feb 2004
    peekskill, NY
    24,473
    4574
    Quote Originally Posted by donie View Post
    Most hardinge beds are three point kinematic mounts to the cabinet. Cabinet only had one extra tab foot in the right rear, just to keep the
    cabinet from getting rocky.
    Sep 2010
    Oklahoma City, OK
    4,484
    774
    1851
    The concept certainly does.
    Aug 2005
    Toronto
    4,824
    3269
    3688
    less than four points its kind of not even a conversation, as in there's nothing to do as there isn't any worry of twist.
    All four feet should take a similar load, I disagree with it level with 3 then use the fourth to stop rocking for a lathe. The might might work on a solid squat shape like a mill base, but not on a lathe of any size where it will twist under its own weight. Get them all in contact and level across the ways (with the level on parallels on the ways, not on the tops of the v's) at the headstock and tailstock. Its nice to have it level in the Z as well. Do a few iterations and and you're done. Its a bunch of bending over and wrenching, but its a pretty simple process.
  9. #8
    Jun 2012
    Davis Junction, Illinois
    158
    50
    26
    If you are having trouble with 4 adjusters, just wait until you get a big boy machine with 6 or more! 😀
  10. #9
    Aug 2010
    Minnesota USA
    271
    43
    OK, How about the the technique for ones with six feet? Four on the headstock and two on the tailstock.
    Ken
  11. #10
    Jun 2012
    158
    50
    26
    Quote Originally Posted by KMoffett View Post
    Ken
    Lathe, PDF Page 80:
    http://victoriacaruk.com/Mazak%20Gen...GENGA0015E.pdf
    Mill:
    Leveling - VMC
