Hi Everyone
I am seeking some assistance with a hydraulic ram. I obtained the table with a fault and thought it was simply a case of needing to bleed the ram. Once fully bled, it was evident that the ram would not retract.
I have attached 4 pictures, the first is of the table itself (or very similar).
Note that the table does not have the more recent cable release mechanism but a rod type arrangement which turns a release valve. The other pictures show the RAM with components removed and labelled to indicate their respective ports.
The issue I am having is that the ram will not retract. While bleeding the ram it was able to, however once I have finished bleeding the ram then it no longer retracts. I have an instinct that there is a spring missing in the release valve on the basis that the other ports have springs and balls.
Does anyone have any thoughts on the release valve (A) components, does it look correct? Am I missing something, should there be a ball in the release valve or something else?
Any help appreciated,
Many thanks
Freddy
Many thanks
Freddy
