J Grainger
Cast Iron
- Oct 12, 2006
- United Kingdom
Hello,
I'll soon be collecting a Taylor Hobson K pantograph. It will need to be lifted onto a trailer.
Am I correct in thinking the best place to lift from (with a strap) is just at the top of the column, at the top of the 45 degree bit, behind the downwards pointing fastener which sort of has it's own boss?
I'm also guessing the copy table can also be removed if the balance point needs to be brought forward a little.
Is there anything else I should or shouldn't do when moving or transporting, or anything fastened which should be removed before lifting or moving?
Thank you
Thank you
