Lite rust removal suggestions.
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Jul 2008
    Philadelphia
    2,098
    576
    484
    Default Lite rust removal suggestions.
    A set of nice 5c collets followed me home a while ago. They are in good shape, all have rust not bad at all, Scotch Brite would do okay for the accessible areas. But I would rather use a liquid +/- ultrasonic cleaner to get inside and out. Any suggestions?
    Jun 2014
    New Jersey
    284
    300
    162
    evapo rust...
    Available at tractor supply or HF
  3. Likes dalmatiangirl61, Terry Keeley liked this post
    Feb 2011
    BFE Nevada/San Marcos Tx
    2,761
    2850
    1757
    Another vote for evapo rust, good stuff.
  5. Likes Jim Williams liked this post
  6. #4
    Jan 2021
    Alabama
    7
    Quote Originally Posted by doug8cat View Post
    ... I would rather use a liquid +/- ultrasonic cleaner to get inside and out. Any suggestions?
    In order of strength and toxicity, have used them all depending upon the amount of rust, rinse with water, then clean dry and lube the part:
    Vinegar in the 6% cleaning strength, dip or ultrasonic use.
    Methyl salicylate aka oil of wintergreen is a good rust dissolver, soak the part then brush off the rust.
    Muratic acid aka hydrochloric will dissolve rust in a hurry, not for ultrasonic use. Brush it on then be ready to quickly rinse in water, but it will also attack all exposed steel and can discolor/etch the surface.
  7. #5
    Jan 2010
    Arizona
    60
    22
    I’ve used citric acid for rust removal. Can be bought on Amazon in powder form, doesn’t damage the metal. Also good for passivating stainless.
    Sent from my iPad using Tapatalk
  8. Likes dian liked this post
  9. #6
    Apr 2020
    Ohio
    962
    923
    340
    Quote Originally Posted by just4grins View Post
    That’s what most of the rust removers at the local Auto parts stores are.
    I use loctite naval jelly. It works great for me.
  10. Likes Jim Williams liked this post
  11. #7
    Feb 2011
    2,761
    2850
    1757
    Quote Originally Posted by kenny256 View Post
    methyl salicylate aka Oil of wintergreen is a good rust dissolver.
    Tell me more! Someone gave me a gallon of that last year, have not found a use for it. In researching it I did find that it is toxic to cats and dogs(?), and people too if too much is ingested, the body turns it into acetylsalicylic acid (aspirin). It is active ingredient in sports rubs like Heat, and one athlete OD'd on it by applying too much.
  12. #8
    Jan 2006
    Brookfield, Wisconsin
    4,267
    291
    424
    Boeshield rust remover. Active ingredient : Phosphoric Acid.
    Been using it for over 12 years. Works pretty good. Can be had at Woodcraft or Rockler.
  13. #9
    Jan 2021
    Alabama
    7
    Quote Originally Posted by dalmatiangirl61 View Post
    Tell me more!
    Try it--test it out on an old rusty piece of metal. Brush it on or let it soak, turns rust into coffee grounds, wire brush and rinse it off. repeat until you like the results. It will dissolve plastic containers, so don't store it in a jug; glass is the best.
  14. Likes dalmatiangirl61 liked this post
  15. #10
    Jun 2014
    New Jersey
    284
    300
    162
    The problem with vinegar and other acids is:
    If you leave it in the acid too long it pits the metal. Also too long and you get hydrogen embrittlement.
    I like the chelating type of rust removal. It's less harmful to the metal.
    I used to use the vinegar, still do on some things. But with caution.
    Use it on my big cast iron surface plate, because it's too big to soak. Just put a wet towel or paper towel on it.
  16. #11
    Nov 2006
    Southern California
    1,127
    11
    144
    I am a still a fan of molasses diluted around 8:1 with water. Here is the before and after pictures of a small Ralmike's hand tapper. It took a few days of immersion. I do lightly kick the bucket daily to mix the solution up. I like that it does not seem to harm the paint and is harmless.
  17. #12
    Apr 2004
    Modesto, CA USA
    8,428
    1597
    EDTA make a glacial solution and it is the same as evaporust without the fancy ph buffer action. Works fine if fully submerged. Any of these methods need full submersion or you end up with a line at the liquid/air inteface.
    EDTA is safe to eat and much cheaper then evaporust. It reduces rust about weight for weight.
    Bil lD
  18. #13
    Jul 2006
    rochester, ny
    2,306
    555
    724
    Bill, what is a "glacial solution"?
  19. #14
    Sep 2005
    Oakland, CA
    2,906
    516
    899
    Ha- a blast from the past- In my younger days, we used Methyl salicylate as a tire compound on our slot car tires to make them sticky! So, if ya go slot car racing, get ur self some!! Those were the days! Pack up a sandwich, grab the box and a few $$ and Zoom!
  20. Likes Rex TX, dkmc liked this post
  21. #15
    May 2020
    Minnesota
    234
    92
    63
    Soft temper wire wheel in a bench grinder and brass pipe brushes with Kroil.
  22. Likes tdmidget liked this post
  23. #16
    Apr 2018
    7,386
    3607
    Quote Originally Posted by Dan from Oakland View Post
    Did you ever go over to the place in San Rafael with the HUGE wooden tracks ? Like, fifty feet long, six lanes wide with high-banked curves like Daytona ? It only lasted about six months but wow ....
    sorry for the interruption, but ... slot cars
  24. #17
    Apr 2020
    Ohio
    962
    923
    340
    Quote Originally Posted by crrmeyer View Post
    It’s not always harmless! Rather hard to swim in I take it.
    Great Molasses Flood - Wikipedia
  25. #18
    Aug 2004
    Virginia
    2,781
    223
    1230
    WD-40 and Scotch brite.
  26. #19
    May 2012
    Pittsford, NY
    1,179
    832
    816
    If you use evaporust, be sure to keep the object fully submerged. Evaporust will eat a line around your item at the air/liquid interface.
  27. #20
    May 2009
    New Jersey
    337
    88
    58
    I have had good luck with regular household white vinegar.
