A little trick for cleaning dingey slip stones.
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Dec 2000
    Bremerton WA USA
    10,701
    41
    4335
    Default A little trick for cleaning dingey slip stones.
    A micro-epiphany:
    I was visiting relatives who showed me their latest gizmo: a knife sharpener that used stones mounted on a sliding rod which guided it at a constant angle over the cutting edhe of the knife clamped in the base. Clever in concept, worked good, but was cheaply made. Amazon has dozens of models differing in price, quality, etc.
    Nothing wrong with the four stones, though. They cut efficiently and the four grit sizes worked well in progression. This started an orgy of knife sharpening 'til every cutting edge in the house was keen as a razor. However, the nice orange mounted stones were all dingey and black with swarf. SWMBO couldn't stand it. She took the stones to the sink and scoured them to like new brightness with Comet cleanser and a vegetable brush. Took minutes.
    THAT was a new one on me. I'd spent hours cleaning slip stones with everything BUT Comet. I went home and tried the Comet trick on some of my ugliest slip stones. Cleaned them right up - except it did nothing for the pins. Some staining remained but they did cut better. YMMV.
    Just saying.
  2. Likes jrmach, tim9lives liked this post
  3. #2
    Mar 2012
    Geilenkirchen, Germany
    2,458
    1464
    1234
    Quote Originally Posted by Forrest Addy View Post
    A micro-epiphany:
    Just saying.
    I have been using those sharpening stones for many years and it is very important to keep them clean. However, I have used them with light weight cutting oil, never dry and never with water. I clean my stones before, during and after use with more cutting oil and a simple wipe with a paper towel. The black swarf is simply wiped away.
    Aug 2005
    Tucson AZ
    6,421
    9747
    3023
    One trip thru the dishwasher and they will look brand new.
    Mar 2017
    199
    99
    I was taught in school to use washing up liquid (dish soap) and a stiff brush with warm water to clean white scintered synthetic ruby slips.
    I'm sure the dishwasher works great, probably just need to be careful about who notices what you are doing.....
    Mar 2005
    Indiana
    4,367
    998
    929
    Bar Keeper's Friend works even better. It has oxalic acids as an ingredient. That means it dissolves some of the tiny steel particles stuck in the stone. Just using some straight mineral spirits as a lubricant and scrubbing the stone on a flat piece of steel will usually clean it right up too. If it's persistently nasty I just re-flatten with a diamond plate.
  7. Likes DavidScott, tim9lives liked this post
  8. #6
    Jan 2013
    Erie, CO
    173
    30
    16
    WD40 works also.
  9. Likes Dumpster_diving, SAG 180 liked this post
  10. #7
    GERMANY
    2,880
    1828
    1038
    Two other tricks:
    - an ultrasonic cleaner
    - if you want it flat for removing scraping burrs, rub it over a sheet of wet-o-dry paper (100 grit works well) lubricated with a drop of dish soap and water. Be sure you have a flat backing surface.
  11. #8
    May 2002
    South Central PA
    13,711
    2328
    3585
    I do the WD-40 trick then lap it flat on a lapping plate with abrasive grit. I think I'll give the Comet a try on the lapping plate.
  12. #9
    Jul 2012
    Washington
    3,008
    1181
    1251
    Quote Originally Posted by ballen View Post
    Two other tricks:
    Lapping stones flat on loose silicon carbide powder, say 60 grit, on a flat surface with some water works much better than sandpaper. The stones will be flatter and better cuttting, but it is hard on your flat surface.
    Here is a video of a new and interesting guided sharpener.
  13. Likes Kevin T, JHOLLAND1, Tool Junkie liked this post
  14. #10
    Aug 2004
    Virginia
    2,401
    178
    946
    You can revive an old stone that has gotten swayback by running over it with a face mill. You have to take care not to get the grit in places it shouldn't be of course. It works really well and the stone is like new.
  15. #11
    Jan 2005
    Houston
    5,853
    580
    2653
    A wise friend of mine says the worst household product you can put down your sink is Comet. Says it gums up the works....I haven't verified this but it makes sense, considering how it looks when mixed with a little water.
  16. #12
    May 2006
    Seattle
    1,961
    38
    373
    When I got an ultrasonic cleaner a few years ago I cleaned all my old slips and hand stones. I was astonished at how clean they came out! What had looked like a nasty gray stone might have turned into a gorgeous matrix of 3 colors. Still, for cleaning one or two stones I think using cleanser would be quicker. I will give it a try.
    metalmagpie
  17. #13
    Mar 2009
    5,317
    97
    1007
    I clean up and true at the same time by rubbing a set of three Bester stones together with water.
    Coarse grit on medium grit (both sides).
    Medium grit on fine grit (both sides).
  18. #14
    Jan 2019
    Hawaii
    319
    135
    53
    Quote Originally Posted by DavidScott View Post
    That would make a nice DIY project!
  19. #15
    Jul 2012
    Washington
    3,008
    1181
    1251
    Quote Originally Posted by GregSY View Post
    Only if you have a septic tank, the chlorine is to be avoided at all costs. The biggest gumming agent for household plumbing is fabric softener, also to be avoided at all costs if you have a leach field.
  20. #16
    Jul 2012
    Washington
    3,008
    1181
    1251
    Quote Originally Posted by Kevin T View Post
    There are far better designs out there, but yeah the difference in how sharp I can get a knife on a guided system vs free hand is astounding. Enough to piss my wife off that the knives are too sharp.
  21. #17
    Jan 2015
    Alabama
    297
    221
    146
    A quick easy way to clean a stone is to saturate with WD40 then stone a piece of cardboard with it. It doesn't get it flat, but a fast way to remove swarf.
  22. #18
    Jan 2007
    Flushing/Flint, Michigan
    8,306
    430
    6842
    WD-40 does not work at all for me. Heck most of the time that is what it's saturated with.
    Scrub bush and Tide, Comet for sure as a go to blow out this. Toilet bowl cleaners also.
    Good sized ultrasonic train and the right stuff in it is magic to unload stones.
    Bob
  23. #19
    Nov 2016
    North Carolina
    105
    25
    46
    I ran a couple sets of stones under a diamond wheel in the surface grinder to flatten things out, they probably aren't Renzetti quality but I think it makes a difference on how well they'll remove burrs without doing damage.
  24. #20
    May 2017
    FINLAND
    1,905
    523
    868
    Two other tricks:
    And electroplated diamond sharpening "stones" clean up nicely if you use them to straighten your waterstone. Or just a piece of red brick.
    If you were stupid like me and scratched the finest 3000 grit diamond plate by cross-contaminating it with swarf and coarser diamond grit just use it to lap some random carbide insert and piece of red brick..
