Heck, this is dreadful if there's nothing like First Robotics, FSAE, or other "Mech" club-like activities you could join at your school.
OK, this'll sound stupid, but it can be very educational. If there's nothing organized in your area, then go to thrift shops and buy some things, like a toaster, oscillating fan, old (mechanical) typewriter, and things of that nature. Nothing over $10.
Also get yourself a good, basic toolkit, including a range of quality screwdrivers, pliers, smaller socket set, etc. And a good DVM (digital volt meter). Don't skimp here, as these should be lifetime tools if treated well.
Now start taking things apart. Look for how the parts are designed, how they're assembled (and so disassembled), and what materials are used for what components. Examine the design choices, why certain fasteners were used, or snap fits, or adhesives. Check out the mechanisms, like a bimetallic thermostat and "lift control" on the toaster. See how the oscillation mechanism on the fan works, and why it's an effective parasitic add-on to allow driving the fan from side to side.
It's old-school for sure, but diving deep into the bits will help you understand practical engineering and design much better than just book learning.
And once you've taken the items apart, put them together again and see if they work. And if they didn't, see what it takes to fix them. Add a soldering iron to your tool kit, but always be very careful when plugging something in for the first time. Check with the DVM for shorts in a power cord or similar "bitey" risks.
If there's a local repair shop or even an auto club of some form, perhaps try to join in an intern-like mode, and help out the expericanced mechanics while asking questions. Most guys/gals are willing to teach if they know you're serious about trying to learn. Or repair bicycles for a local charity, anything to get your hands dirty while the mind is engaged.
Hope this helps - the best students I've worked with have had a balance of classroom and hands-on learning, and many have gone on to start companies and design some very cool stuff.
And wear safety glasses if you don't use specs to begin with. Some springs or sparks may target your eyeballs, and you really want to keep those in good shape for as long as possible.
