taiwanluthiers
Cast Iron
- Dec 6, 2016
- Xinjhuan District, New Taipei City
I just moved into a new shop in Taiwan. It’s a 3 story residential construction, old building but built out of reinforced concrete and brick facade. I’m on the second floor and the floor is 6 inch concrete slab with I think at least 1 inch steel rebar as reinforcement. The span is 2.5 meters and the support beams are basically 18 x 18 inch reinforced concrete beams that are really strong.
My question is assuming I can get the machines up there do you think it will support a 4000lb Bridgeport type mill? I can get 3 phase power brought in if necessary as the tenant on the first floor is a factory.
