Lock-out Tag-out
Results 1 to 7 of 7
    Mar 2021
    CANADA
    Ontario
    Smile Lock-out Tag-out
    Hi,
    I have a custom machine shop. We have been struggling for YEARS with finding a way to do lock-out/Tag-out on our brake presses. We change dies like pretty much even half an hour. We have moved to the Wila system, so the die changes are much easier but we still have a lot of our older dies that are conventional. How do you guys deal with going into the back to change them without having to log off and shut down the machine?
    Oct 2005
    22,051
    Quote Originally Posted by yassybassy View Post
    Hi,
    Make up some custom tools & fixtures to keep you workers out of harms way.
    Have you talked to Rockford ?
    Machine Safeguarding Solutions - Rockford Systems, LLC
    Sep 2005
    Oakland, CA
    3,008
    583
    959
    One approach might be to wire key switches into the control circuitry. Operator locks the switch in the off position and puts the key in his pocket.
  4. Likes idacal, sfriedberg liked this post
    Oct 2010
    Oregon
    5,746
    5660
    2204
    Traditional lock-out/tag-out is based on removing power from the machine. A "lock out" with the controller up and running is a whole different ball game. It's the difference between "physically cannot" and "trust that it will not".
    If there's an existing safety interlock on the brake, then you can wire additional NC LOTO switches in series with the interlock.
    If there's no existing safety interlock, and nothing in the controller ladder logic intended for that purpose, then you get into a delicate situation. You need somebody qualified to work on safety circuits to evaluate your machine (which means us floating out here on the InnerTubes are not your solution) and determine exactly what it needs to add an approved safety circuit. Without a licensed engineer's stamp (and quitely likely even with one), your regional safety organization (Canada and its provinces have them, I am sure) will not be happy. $$$$
  6. Likes digger doug liked this post
  7. #5
    Dec 2005
    Wisconsin
    1,026
    20
    191
    Most of the machines on the production line don't like being locked out. They have key switches on the controls. To really lock them out, it kills the computer controls and the freq drives. I only go in when I have to measure something and the mechs get pissy about me killing all the power cause they don't start up well.
    Engineering design foul up in my opinion. I don't think locking out for safety should be difficult but it often is.
    Dave
  8. #6
    Nov 2008
    Madera county california usa
    2,724
    21
    720
    Is there a way to insert a locking pin?
    Something that prevents the machine from acting physically?
  9. #7
    Dec 2012
    Se Ma USA
    2,240
    180
    1219
    I am stumped. Is a brake press different than a press brake? Because I change all tooling from the front. To go in back I need to open a door that has a switch that activates the Estop. I think I have been inside the machine maybe 10 times in the last 4 years. When I drop a part.
