garcher
- May 7, 2011
- Georgia,USA
Looking at a L&S Powerturn 2013 1962 Model.I test ran it and it has a couple of issues.When I run it at 550-700 rpm machine had a vibration ( you could see the headstock moving).Im thinking maybe machine is not level and is on uneven floor.The machine seller bought it from a textile mill and moved it to his shop.The round numbered dial on the feed box will not turn completely to select all the feeds.Also the numbers don’t line up with the mark.Ways look great and compound has only about .005 backlash. I know it’s an old machine so should I be overly concerned.Thanks for any comments and guidance.
Glenn
Glenn
