rgnoll
- Aug 13, 2004
- Seattle, WA
Hello
I have a Logan Lathe (mdl 815) that I'm upgrading the motor and replacing the reversing switch on.
The motor I'm installing is a Marathon Cap start 3/4hp, dual voltage & reversible. I will be running it on 110v.
Pic of the wiring diagram from plate attached.
The Drum Switch is a Furnas mdl A-14 / A14. It is a 3 position switch with Off in Center position with Forward & Reverse on opposing sides. Note the terminal connections are not #'d 1 thru 6 as many are. I understand that line leads go to A & B. Not sure which would have the Hot lead (black).
Pics of the switch, connections & terminals attached.
Appreciate greatly any help on wiring this up. Should be noted that I am not familiar with terms such as start & run windings.
Accordingly, basic "connect T1 to terminal 4" would be most helpful....
