Looking for 3/4-12 spade head screw
Results 1 to 6 of 6
    Feb 2002
    Peralta, NM USA
    5,639
    48
    461
    Default Looking for 3/4-12 spade head screw
    Think of an overgrown thumb screw and you're in the ballpark. I can't find any of these myself but I thought I'd ask here before I make one. I need one 3/4-12 (yup, 12) and 5 5/8 OAL or better - this is the adjuster in a sheet metal roller and the far end needs a groove to engage one roller's end assembly. I've got the material but it's going to be a fair amount of hogging 4140HT to get it down and figured I'd check for one close before I start.
    Feb 2006
    Indiana
    12,776
    647
    3766
    I have made such things by silver brazing a steel flat washer into the slot of a round head screw. In other words, you can make your 3/4-12 screw out of 1" bar or even 3/4" bar if you don't need a shoulder. Then add the washer, and you don't need to hog it from a bigger bar.
    Larry
  3. Likes Gordon Heaton, TDegenhart liked this post
    Feb 2006
    Indiana
    12,776
    647
    3766
    Here is another possible solution, which can also be made from 3/4" bar. Drill and tap one end of the 3/4-12 bar a standard size like 1/2-13. Then screw in a forged eye bolt with shoulder and possibly a flat washer. Set the eye bolt with Loctite.
    I made a set of pins for locking the columns on my telescoping gantry using eye bolts for handles and they look and perform very well.
    Bolt Depot - Forged Eye Bolts with Shoulder Dimensions
    Larry
    Sep 2016
    Missouri
    778
    665
    217
    Would these save some work for the wing. Weld, braze or tap and screw onto your threaded rod.
    Thought came from L Vanice's post
    USA Made
    Crosby(R) S-264 Pad Eye
    Feb 2002
    Peralta, NM USA
    5,639
    48
    461
    Thanks for the suggestions. If it were my sheet metal roller all of those would be viable suggestions, but it's for someone else. I may get away with just turning the 3/4-12 in some stock and welding the old "thumb" on it - I'll ask if that's a viable solution for the user.
    Mar 2011
    Geneva Illinois USA
    6,017
    2512
    2335
    You could forge the end.
    Tom
