Looking for 4mm-.075 fillister head screws
Likes Likes:  0
Results 1 to 13 of 13
    Jun 2008
    Nashville, TN
    5
    Default Looking for 4mm-.075 fillister head screws
    I'm building a component to fit an existing item that uses 4mm -.075 fillister head screws. I need some longer ones but can't locate them thru any of the big distributers like MSC, Grainger, McMaster Carr, Fastenal, Small Parts, Berg, Lowe's, or Home Depot.
    I have a tap and die this size so either I'm not looking in the right place or they've all been destroyed.
    Any info would be helpful. Thanks.
    Feb 2006
    Indiana
    13,133
    721
    4071
    M4 x .7 is the common ISO thread. You probably meant you are looking for M4 x .75, which is probably in an older component. A .075 mm pitch is 339 TPI, really fine!
    Larry
    Jun 2008
    Nashville, TN
    5
    Yeah I was going off of what the tap read which was the 4mm - .075 and the M4x .7 is all anybody has but obviously doesn't fit. I'm thinking about making some but didin't want to go that route if I could find some.
    Jan 2007
    Norfolk, UK
    19,642
    15080
    15249
    FWIW;- I can't help on where, but IIRC 4 x 0.75 is an old German DIN standard, possibly pre WW2 if that's any help.
    Feb 2006
    Indiana
    13,133
    721
    4071
    And Google reveals that the rear sight screw for a Model 1938 Italian Carcano carbine has that thread. More likely old than new design, so new screws would be a DIY job.
    Larry
    Jun 2008
    Nashville, TN
    5
    Thanks for the help. I guess I'll get to making some then.
    Feb 2007
    Angleton, Texas
    1,714
    939
    536
    Making which one?
    M4 x .75 or M4 x .075?
    Jun 2008
    Nashville, TN
    5
    I guess I'll make the M4X .75 which is confusing to me because I have a tap the reads exactly, "4mm - .075", but I can only find a die labeled as M4x.75, so I can only guess that they coincide, although I know that .75 and .075 aren't the same. I just chalked it up to a metric thing, or the tap is mislabeled. I don't know who made the tap, but it was made in the states. I've had this hassle all day and can't get a straight answer. So if I've got a tap labeled as 4mm-.075, then a die labeled as M4x.75 will not work, is that what I'm understanding? Or is possible that the tap is mislabeled?
    Feb 2006
    Indiana
    13,133
    721
    4071
    Well, .75 mm is the same as .075 cm. People who understand and use the modern metric system call out thread pitch in mm. But 60 to 100 years ago, Americans called out metric threads in threads per centimeter, which is not at all the same as the modern metric pitch designation. For instance, a 1 mm pitch is the same as 10 threads per cm and .75 mm is 7.5 threads per cm.
    You said the tap is US made, so maybe it was made when Americans did not fully understand how to describe a metric thread, but had adopted the metric pitch scheme. I expect the tap will fit your existing holes. You should have no trouble eyeballing the difference between 34 and 339 threads per inch.
    Larry
    Jun 2008
    Nashville, TN
    5
    That makes sense. I don't deal alot with metric so this whole day has been a nutroll trying to make sense of it and come up with a solution. Thanks for taking the time to explain that.
    One thing though, the tap doesn't appear to be that old, which aided in the confusion. I'll know for certain tomorrow when the M4x.75 die arrives and I make the first screw. Thanks again.
  11. #11
    Feb 2008
    Illinois
    1,107
    65
    395
    Standard M4 has 0.7 mm pitch.There is also M4.5 with a 0.75mm pitch.
    There is NO M4 x 0.075!
    Check if you don't have mislabeled 8-32 or 8-36.
    There is also a Metric Fine M4x.2,M4x.25, M4x.35 and M4x.5 Very rare!!
  12. #12
    Oct 2010
    Oregon
    5,291
    4741
    1939
    This thread (M4x0.75) came up in another thread (forum) a few days ago. IIRC, it was previously used widely in Japan, but is no longer a preferred thread there.
    No matter what is stamped on it, the OP certainly does not have an M4x.075, as you'd have a hard time distinguishing .075 threads from a rough-turned cylinder. .075 != 0.75
  13. #13
    Dec 2012
    AUSTRALIA
    2,830
    12
    913
    The 4mmx .75mm thread is old metric standard,adopted by the Japanese as JIC ....there are a number of other sizes too ,which dont correspond with ISO....Its a common thread in pre 1970s Japanese consumer goods ,like cars ,motorbikes ,and electricals......and machine tools .
