Looking for a fastener - 1/2-13 x 1/2" cap screw center drilled/tap like "vent" screw
Results 1 to 12 of 12
    Nov 2010
    Tustin, CA
    500
    353
    154
    Default Looking for a fastener - 1/2-13 x 1/2" cap screw center drilled/tap like "vent" screw
    Do these exist commercially? It's basically to use as a locking mechanism to set tension on a simple assembly with a wave spring. Obviously they are straightforward to make, I'm just curious if they are already offered somewhere. I checked McMaster and vented screws are available, but the sizes stop at 1/4". I can make them if need be, but was just curious if someone already make something like that. I drilled and tapped one yesterday on the lathe and it works for what I need. I'm able to set the tension of the 1/2-13 and then just reach down the center and use a 1/8 allen to bottom out a 1/4-20 to bind up the threads. Looking at just using loctite as well.
    Oct 2005
    21,690
    Quote Originally Posted by kazlx View Post
    Doo you mean like the head is "drilled for safety wire" ?
    Nov 2010
    Tustin, CA
    500
    353
    154
    No, drilled along the axis of the bolt. Like a vented bolt. I doubt I'd find drilled and tapped, but thought maybe I can find them already drilled and just tap them.
    Feb 2016
    Washington
    295
    527
    165
    You're chances of finding them pre-drilled in a useful tap drill size is probably pretty low.
    How many are you expecting to need?
    Nov 2010
    Tustin, CA
    500
    353
    154
    Quote Originally Posted by J Gilles View Post
    That's what I was figuring, but it never hurts to ask. Probably 500-1000.
    Feb 2016
    Washington
    295
    527
    165
    You might reach out to a custom screw manufacturer and get them quoted. If they are already setup to run custom cap screws, adding a drilling operation that isn't very deep shouldn't be difficult. Plus they could probably send them to you tapped so you can just install them and save some of your time.
    Oct 2005
    21,690
    There are members on here that doo this kind of work.
    Simply post the details in the Manufacturing Resources section.
    Sep 2007
    Washington
    5,677
    280
    1895
    At that quantity, it might make sense to have someone run them in a VMC. Machine a couple high-density fixtures and do them 50 or so at a time.
    Regards.
    Mike
    Nov 2010
    Tustin, CA
    500
    353
    154
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    That’s basically my plan. I’ll just modify the stock hardware myself if need be.
    Oct 2010
    Oregon
    5,714
    5593
    2173
    Set screws with through hex holes are a standard part. "Hollow-lock set screws" or "jam set screws". The 1/4" hex through hole on a 1/2-13 jam set screw would be big enough to get a 1/8" hex key through, no problem.
  11. Likes kazlx liked this post
  12. #11
    Apr 2004
    Modesto, CA USA
    8,541
    1632
    I know them as vacuum screws. This outfit has 1/2-13.
    Bill D.
    Inch Socket Head Cap Screws | CDS
  13. Likes 1yesca liked this post
  14. #12
    Jun 2004
    642
    525
    118
    Quote Originally Posted by Bill D View Post
    Bill D.
    now that is some cool stuff looks like they have it all
